basically im talking about 150kmh and upwards on the track of course.
so my first question what should i spend my first dollars on... 2.5" full exhaust or something... please lead me in the right direction and no i dont have a endless amount of money![]()
4 into 1 headers, 100 cell cats, twin 2 1/2'' catback, mafless tune and otr should make it more fun. Then think about doing your diff gears.
electric supercharger from ebay?
Like this one selga86?? haha
Electric Supercharger Turbo Nitrous All Cars +MPG/+HP | eBay
haha yer and a $20 chip off ebay hahaelectric supercharger from ebay?
To OP, as i say to everyone, if you dont need a tune after doing a mod there will be bugger all difference. may as well do the cam, the rockers and mabe the heads, then do little things like the exhaust and intake. and if you do a normal tune instead of a mafless one, you should be able to add the exaust and intake later down the track with out retuning it as it should re-adjust by it self.
FIRST CAR
'96 VS Executive 3.8L
any fat chicks in the back? that usually causes lack of power and bad fuel economy
The exhaust will make a huge difference. The stock manifolds and exhaust are really quite restrictive. You should do the exhaust BEFORE you change internals, why put in a bigger cam to get more air in and out but leave the restrictive exhaust on it to choke it up?
The PCM doesn't adjust, it compensates. It only uses timing and fuel trims to compensate for differences in conditions, it doesn't really adjust the tune itself.
cams and heads are usually the most expensive and the last things you do
can you get a set of cams bought and installed for less than $2k???
If your LS1 is no faster than your old Ecotec, first go fix whatever is choking the poor thing before you go about modifying it.
yeah it goes without saying
above 150km/h, the LS1 does not let up, 4th and 5th gear easy
the Ecotec is struggling hard
top end is where you should notice the most difference. my ss is only a 5L and it pulls away from v6's, more noticeably in the >100 range, an LS1 should be getting better then that, much better.
interesting read, i thought my 5.7 was slow but then i drove a new sv6 thunder that feels slow! i have only had turboed cars till i got my ss
exactly like that one
