Results 1 to 19 of 19
Thread: Manual or Auto?
    VX 3.8 S1
    May 2011
    Default Manual or Auto?
    Hey guys,
    New to this forum so excuse my ignorance to anything haha
    I've had my VX commodore for around a year now after upgrading from a vectra :P
    I don't miss it as such but I do miss a manual gearbox, auto is killing me.
    Manual conversions turn out to cost a fair amount so I'm looking at seeing if there's anything I can do to upgrade the auto gearbox at all?
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Trans-go stage 3 full manual reprogramming kit.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    VX 3.8 S1
    May 2011
    VT calais 1999
    Jun 2009
    Gympie
    hey mate i was the same when i got my vt s2 Calais i did alot of looking around spoke to a lot of people about what the best upgrade for my gear box about a month of looking round and asking question i ended up getting a stage 2 shift kit and i would have to say it i love it i can change up and down gears and also leave it in drive for city drving i paid around 800
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by gotham.r View Post
    Hey guys,
    5spd Getrag Conversion would be around $1500 i reckon, assuming you and your mates can do it yourself.
    otherwise a shiftkit, transcooler, and fit a set of 3.9's and feel your auto come alive.
    If it isnt tuckin, it must be suckin
    VX 3.8 S1
    May 2011
    Quote Originally Posted by holden_calais_VT_1999 View Post
    sounds alot cheaper than a full manual conversion then. where did you get yours from?
    VX 3.8 S1
    May 2011
    this may sound a bit stupid but after you install a shift kit for example stage 2, how does it work from the actual shifter inside the car? what changes?
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    from memory a switch is installed inside the car, that allows you to turn it on and off. the different stages refer to stage 1 being either on or off, whereas stage 2 allows you to select the desired firmness.
    VX 3.8 S1
    May 2011
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    No. It firms the shifts up, that's it.
    To hold gears you either need a manual, or a manualized valve body for your auto.
    VX 3.8 S1
    May 2011
    so even with a stage 3 you can't actually hold them even though you have to manually change the gears?
    thanks heaps for your help by the way!
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    a "stage 3" is a manualized valve body im pretty sure. so with a stage 3 you HAVE to change gears manually, ie. if the shifter is in drive, the box will select 4th and not change. you will have to select 1 to take off then shift to 2, etc.
    VT calais 1999
    Jun 2009
    Gympie
    hey mate i got my done at a transmission place in gympie and the one i got allows me to hold each gear to the limiter. and in my opinion it shifts faster then a manual chirps the tires from first to second and second to third if ur really feeding it
    VT SS S2 A4
    Aug 2005
    Change the servo also, that will firm up the shifts. I went with billet servos for mine, but you could go the corvette servo also which is an improvement over standard but not quite as firm as billet.
  15. #15
    ewt
    ewt is offline
    VT Wagon & VZ Berlina
    Mar 2010
    Sunbury, VIC 3429
    A stage 3 kit sounds good, but if you want a manual, you'd be better off finding a VT or VX that came out with a Manual. Maybe something like an S-Pac.
  16. #16
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Yeah manual mite be the way to go mate..
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
  17. #17
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Quote Originally Posted by GEN3RATD View Post
    Correct. Ive got a vs calais 5l with a manualised auto. There is no drive gear anymore. You have to change gear all the time. Just like the v8's use (kind of)
  18. #18
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    its a good idea, i would prefer a manual over it though for this sort of car. when i think of manualised autos i think of 1000rwhp builds.
  19. #19
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    i would go a manual v6 conversions are easy to get and its not that hard to do really everything just bolts in place i did mine myself over 2.5 days only working on it while kids were in school.
    mine cost me little over 2g but i replaced all bolts and was missing alot as the wrecker i used didnt have a complete v8 conversion.
    but if there is nothing wrong with the auto than yeah the prices are going to be way cheaper doing something to the auto you have.
  1. [VIC] T5 Manual G/box out of 88 VN Wagon. Everything for full Auto-Manual Conversion
    By Shaz77 in forum Parts And Other Items For Sale
    Last Post: 11-06-2011, 04:05 PM
  2. Replies: 7
    Last Post: 21-07-2010, 10:45 PM
  3. Vr auto to manual using Vs manual/comp
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 07:20 PM
  4. Please Help, Doing manual conversion and i used the auto flexplate bolt on manual fly
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 08:52 PM
  5. VN manual now with a VR Series II motor w/auto loom but a manual. Crank'n issues
    By Illuminatis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2009, 07:03 PM
