Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By PRAVX II S
Thread: VT idle's fine soon as you rev it / drive it missfires and wants to stall
    98 VT Executive
    Aug 2011
    Australia
    Default VT idle's fine soon as you rev it / drive it missfires and wants to stall
    Hi Guys , i need some help with my 98 vt commodore well i was driving home yestarday and all of a sudden i noticed the car had no power had my foot to the floor wouldnt go over 80 i manged to get home then had to go out again but it got worse now the car sounds really bad when you give it abit of throttle and has no power if you push the throttle abit the car will missfire and want to stall
    any idea's on whats causing this
    Thanks Chris
    Vt commodore
    Nov 2010
    Mt Druitt
    change the plugs and leads also check the coil pack undo the wires from the coil and check all the little pins are there if any are missing change the coil pack, i had the same problem and mine was the plugs now it runs fine hope it helps
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Plugs and leads
    When was the last time u changed ur plugs or leads?
    98 VT Executive
    Aug 2011
    Australia
    changed the leads and plugs yestarday cause thats what i thought was wrong with it but it made no change like i said it idle's no problem you can rev it to 3000rpm its still fine if you put your foot to the floor it missfires and stalls also has no power when driving wont go over 20kmh
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    Quote Originally Posted by chrizza132 View Post
    did you check the posts on the coils? if they are discoloured or rusty its more likely rooted. could also be the module(the piece the coils bolt to).
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    vx s pack II
    Jan 2010
    aLKIDA
    Check for weak spark, if the spark is ok,
    I would check the fuel rail pressure while revs are up.
    VX series I I ss
    May 2011
    brisbane
    Best way to check coils is disconnect both leads on one coil pack at a time then start the engine . If the coil pack is good there should be a solid spark between the terminal posts ,if not replace the coil .
    If you don`t want to break it , then don`t bring it out to play with it !
    vx s pack II
    Jan 2010
    aLKIDA
    The best way to check the coil pack is actually reading the resistance of the primary and secondary windings to spec
    The best way.
  1. Car Idle's to 200rpm in park
    By barinakid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2011, 07:00 AM
  2. idle fine,drive like shit!!
    By a9xtorana in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-12-2010, 06:45 PM
  3. Vr 6 idles iratically in netral and try's to stall when changing from reverse/drive
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2009, 07:36 PM
  4. VT missfires only at 80k.
    By jindy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2008, 10:46 PM
  5. VS wanting to stall from drive to reverse
    By silvr6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2006, 04:38 PM
