Results 1 to 6 of 6
Thread: 5.0 vt commodore wont start
    jpg
    jpg is offline
    VT GTS
    Aug 2011
    Sunshine Coast
    Unhappy 5.0 vt commodore wont start
    I went to start my 5lt vt commodore today and when I turned the key it just made a clicking noise and the motor wouldnt make any noises at all. All the interior/exterior lights, CD player etc were working and the battery is fantastic, all the fuses are fine,
    I roll started it (its manual) and it worked perfectly, left it running for a while then turned it off. When I went to start it again I had the exact same problem again. Any ideas what it may be? thanks.
    Vx2 Calais 5.7
    Jul 2011
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Why do you say the battery is fantastic? Have you had it tested or is it a recent purchase?
    jpg
    jpg is offline
    VT GTS
    Aug 2011
    Sunshine Coast
    its a brand new battery, i tested it and it was fully charged. when i turn the key i can hear one single click noise coming from the engine bay
    ewt
    ewt is offline
    VT Wagon & VZ Berlina
    Mar 2010
    Sunbury, VIC 3429
    It's either the Starter Motor, or the Alternator. If not those, then the Earth Straps?
    Aug 2004
    Try to start it using some jumper leads. You need to test the voltage of the battery when it is under load (in your case when you turn the ignition to start). Also check the wiring from the starter motor to the battery. Have you made sure that the clamps on your battery are nice and tight. Some batteries have smaller terminals which don't allow your clamps to tighten properly.
  1. car wont start vs commodore
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2010, 05:57 PM
  2. VC commodore wont start
    By GeoffreyDarts in forum General Discussion
    Last Post: 27-05-2010, 07:52 PM
  3. vn commodore wont start
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2010, 07:28 PM
  4. vt ss commodore wont start
    By steve67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2009, 08:26 PM
  5. vs commodore help..wont start
    By 21AZE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2006, 11:08 PM
Tags for this Thread
