Results 1 to 8 of 8
Thread: VT Bullbar question.
    VT Berlina
    May 2011
    Chirstchurch
    Default VT Bullbar question.
    Hey guys and gals I'm new to the forums so be nice please
    Anywho a couple of questions,
    I've been looking through the forums and everybody seems to say if you're installing a non factory bull/nudge bar it needs to be "airbag approved" Now my first question is the airbag impact sensor on a VT is inside the car beneath the center armrest console so wouldn't any bullbar mounted to the chassis be fine to use as it shouldn't affect the sensor? If I'm wrong please let me know, secondly my car didn't come out from the factory with a bar so will it still have the proper mounting points and if so where would I find them?
    Thanks for looking and if it helps my car is a Series 1 VT sedan 3.8L
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Welcome to the forum.
    The SRS sensors only sense deceleration, not actual impact. A bullbar has to be airbag compatible because it can't affect the rate of deceleration sensed if the bullbar wasn't there. The mounts and the bullbar itself have to crumple at the same rate as a bumper so it doesn't affect how the sensors trigger the SRS system. There is no actual sensor that is at the front of the car that senses an impact.
    The SRS system is designed to trigger when deceleration is equivelant to hitting an immovable object at 40km/h or greater. If the bullbar were too rigid, then the sensors may trigger when doing under 40km/h making an airbag deployment dangerous. If the mounts were to collapse at too fast a rate, then the airbag may not trigger until a higher speed, putting the occupants at greater risk of injury.
    Each bullbar or nudgebar has it's own mounting system, they can utilise the existing bumper mounts or they have their own brackets and mount to different places. It all depends on the style and brand. The car itself doesn't have existing bullbar mounts as such.
    Visit my Facebook page
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Not_An_Abba_Fan
    Hey mate, do you have any idea where to look at getting a bullbar for a Commodore? And how much it might cost?
    Thanks,
    Mike.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    What sort do you want? There are a few manufactures that do them. Smartbar do the plastic bar, ECB do a tubular style bar, Bluey's Ute World do the big 5 poster as well as a few places over here that manufacture their own.
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Sort of thinking this style:
    Just found it on google, but I've always like that style. Balances nicely on a Commodore, don't think the snow ploughs work on Sedans.
    2001 VX Executive
    Dec 2010
    Look it up on a map, NSW
    I used to run a bar on my VX. The one I ran was a factory holden iten that mounted on the steel reinforcement behind the plastic cover, all I know is that this was airbag funcion would not be affected and it mounts with 4 bolts
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by MikeCuzzy View Post
    Click image for larger version.
    That's called a nudge bar. Pretty cheap, most people that sell bars can do them. They are around $500.
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Ahh, Nudge Bar, noted. Lol, only just started with the idea of having one, $500 sounds really good, guess that's going on the wish list. Thanks mate, much appreciated.
  1. VU-VY-VZ Bullbar
    By VzVzVz in forum General
    Last Post: 03-01-2010, 11:23 PM
  2. bullbar
    By steve40 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-06-2009, 08:39 PM
  3. Bullbar for vn
    By Bnsbeaver in forum VN - VP - VG - VQ
    Last Post: 17-02-2008, 04:34 PM
  4. bullbar
    By Patrio7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2005, 12:22 AM
