hi guys,
i seem to have some play from left to right in my front left wheel. my front right seems okay. i have recently had all the bushes replace in the front z bars but it hasnt fixed it. i checked all the wheel nuts aswell and none of them are loose. what could my issue be? any help would be great.
Cheers Simo
they are just the stock wheels its a VTII berlina sedan. ill take the wheel off n swap it 4 c if that fixes it. cheers
Is it up and down as well it might be a stuffed hub bearing?
Jack it up and try to move it up and down.
perhaps it's simply a tie rod end???slide under the front of the car and get a friend to grab hold of the wheel itself and try to turn it from side to side .you should be able to see where the movement is.good luck
Tie rod end or wear in the steering rack.
