Results 1 to 6 of 6
Thread: vx ss 6sp shifter stuck in 3rd
    VX SS M6
    Jun 2005
    Unhappy vx ss 6sp shifter stuck in 3rd
    just driving home normally into my street had it in 3rd rolled into my driveway and opened the garage went to put it in 1st and my shifter is just stuck in 3rd gear. so just rolled it in, turned the car off pumping the clutch trying to take it out and its completely jammed wtf, scared if i keep forcing prob gonna bend something. any ideas really pissed off atm. clutch operation is fine. no noises,problems prior to this.
    any help appreciated
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    have you checked the transfluid level? lack of fluid causes gears to stick but that usually has a noise before the gears no longer shift. i assume youve tried to change it out of 3rd without the car on. start with small things work up to bigger things.
    I know its Hello Capitan Obvious but just a suggestion.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VX SS M6
    Jun 2005
    yea changed the fluid about a month ago nice and full. yea i tried to get it out of 3rd with the car on and off pumping the clutch
    fitz_vt's Avatar
    Nov 2008
    things you may want to check all guide pins and linkages, if there is any freeplay(side to side you may be able to wiggle it out of gear) in the gear stick?
    if not that may suggest an gearbox problem. (others may tell you otherwise im no mechanic and i drive an auto)
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by fitz_vt View Post
    We dont have linkages or guide pins on our manual commodores.Its called "Remote Linkage",like this one;
    Attached Thumbnails Attached Thumbnails vx ss 6sp shifter stuck in 3rd-snap_2011.08.14_12h22m11s_002.jpg
    VX SS M6
    Jun 2005
    i was reading on other forums, that the gear seclector forks have nylon pads on the end of them and they wear and fall off causing this and seams to be a common problem. they normaly get replaced with stronger bronze pads hopefully thats all it is and doesnt cost me too much
  1. Shifter Issues, Getrag 260, Shifter partern is more forwards and to the right
    By BIG-EV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2011, 07:13 PM
  2. Stuck CD
    By f1_power in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2010, 10:44 PM
  3. cd stuck
    By redvs2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-06-2010, 06:03 PM
  4. What Ya Got Stuck On Ya Car
    By soulyouth in forum The Pub
    Last Post: 04-08-2005, 09:21 AM
  5. Stuck?????
    By liquidforce_134 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2004, 07:48 PM
