Hey gang what up?
I bought a holden VT and wanted to use something in the cigarette lighter so it can play music, anyway.
Its an empty hole, i took off all the required plasic covers and found there are just 2 wires there, 1 is brown and the other wire is black. I have not seen
a VT cigarette lighter setup before but i assume you just wire up a cigarette lighter unit and mount it in the hole that i already have?
Can someone confirm this and maybe give me some more information how to approach this? eg ways to make it stay in there once i have it wired up?
Thanks
common fault
the VT plug is screwed to weak plastic
you can easily get it rewired up
I know i could easily get one wired up but i wasnt asking if i could get one easily wired up.
I was asking if someone could (and ill be more clear) guide me vaguely through the process of holding the cigarette lighter in my hand/connecting the wires to it/ fitting it to the hole, and making it stay there.
I could go outside right now and have a "crack" at it but i thought there might be a person who has fixed this (as TonyJZX said) "common fault"
Thanks
