Results 1 to 5 of 5
Thread: Problems replacing rubber front brake lines in my VX ss
    Holden Commodore VX 2002
    Jun 2011
    Default Problems replacing rubber front brake lines in my VX ss
    Today i went to replace my brake fluid and swop the front rubber brake lines with braided lines.
    It said in the manual that were the line meets the steel pipes , on one side of the bracket it holds using a clip.
    Mine is one piece and it cant be taken out, unless i grind it out and get s new surclips to hold them in place for the upgraded ones.
    Heres a picture Problems replacing rubber front brake lines in my VX ss-16082011370.jpgProblems replacing rubber front brake lines in my VX ss-16082011369.jpgProblems replacing rubber front brake lines in my VX ss-09082011368.jpgProblems replacing rubber front brake lines in my VX ss-09082011367.jpgProblems replacing rubber front brake lines in my VX ss-09082011366.jpg
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    I reeeeeallly dont know what the hell you've done to that brakeline coming through the guard?
    Pictures arent clear, neither is the description. Hose from caliper scews into bottom of that bracket, which is where the metal line from the MC comes in.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Jun 2011
    Default Trouble removing hose from bracket
    Sorry for my lame discription when i wrote this i had a few schooners!!
    The problem is in the gregory manual it says the hose is secured by a surclip onto the bracket which then connects to the metal line.
    When i went to remove mine, there is no surclip and the hose seems to held there by a ring of pressed metal. (see photo 1) I even went to my local garage and he said its definetly not a clip and that the only way to remove the hose from the bracket will be to grind the lip out ( see photo1) and then get some surclips for my new braided ones.
    Every thing else in fine this is the only problem!
    Hope thats better explained now!
    Thanks
    Ben
    VT
    Feb 2010
    Yeah I see what your talking about, I'm sure there should be a clip like this on there
    Has your new rubber hose got any groove in it for the clip ?
    Jun 2011
    No there was no clip like that on there , it seemed like a metal ring was machine pressed in there no way of getting it off.
    On the bracket it slf it has the brake company logo stamped on it so im guessing it comes complete with bracket if you buy them from holden.?My dads mate whos been a machanic for 30 years has not seen it before.
    I grinded the lip off so i could remove the old rubber hose, had to file the hole a tiny bit bigger to fit my new braided brake lines. Brought new surclips and put a couple of drops off a mig weilder to stop any movement.
    I will post up pictures when i finished with them on the car.
    Thanks for any help.
  1. Front braided brake lines
    By Exidor in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-12-2009, 08:40 PM
  2. VN brake lines
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2008, 09:02 PM
  3. Replacing front brake pads
    By Jamkat in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-07-2008, 03:44 PM
  4. Brake lines - rubber vs braided
    By ephect in forum General Discussion
    Last Post: 18-04-2007, 11:41 PM
  5. Replacing VT front brake discs and pads
    By flukey77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2006, 10:25 PM
