Results 1 to 4 of 4
Thread: VX Power Antenna Not Working..
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Default VX Power Antenna Not Working..
    Hey guys,
    Having a slight problem with my power antenna in my VX Lumina.. the antenna is stuck up and I can also hear the motor run everytime I turn the key on and off. So it is trying to put the antenna up and down but with no success.
    What do you guys reckon is the problem? I'm leaning towards the antenna been out of place or something like that but don't really know where to start and hoping someone here can give me some advice on what to check to fix this..
    Cheers,
    Nick
    Check It Out
    My 93' VR Executive
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    you need a rope and mast
    the plastic rope that attaches to the cog inside the aerial motor breaks off and wont retract...
    if you turn ignition on and radio on so it should be all the way up
    then lean in car and turn radio off while pusshing down ontop of the aerial it should go back in but will get stuck when it goes all the way up again...
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Sweet thanks for the quickly reply mate.
    Whats the rope and mast like to replace? Any threads explaining how to do it or is it pretty straight forward?
    Check It Out
    My 93' VR Executive
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    not sure, search maybe lol~!
    push aerial in as far as you can while radio turning off
    ignition off
    take front left wheel off then inner gaurd and mud flap
    then 13mm bolt on aerial motor AND screw for static earth above motor (leave inside gaurd) and connector/plug
    then (my way) attach a (exposed end of wire) wire to the bolt ONLY on the motor and nip it up by hand
    then attach other end of wire to the screw for the static earth cable and nip it up (without the static cable)
    connector plug for aerial motor plug back in
    pop lh indicator lenz out of gaurd
    stick end of motor through hole in gaurd for indicator
    undo 13mm silver cap on end/top of aerial MOTOR
    take cap off over the end of mast
    turn radio on
    pull mast and antena out all the way whil its turning on(going up)
    get new one from holden lol
    put rope end into motor
    turn radio off and feed rope into motor (is tricky take a few goes to get it right)
    once motor stops put 13mm cap back on and nip it up
    once motor stops if not in far enough try again (2seconds on then turn off and push down again)
    then turn it on again and it will go all the way up and click lots then turn it off and it should go all the way back in
    if it doesnt work as above you buy a aerial motor WITH mast and replace the whole thing it sucks but thats how
    you gotta do it either way you gotta pull gaurd (inner) out...
    or take it to your professional.......
  1. Power antenna not working with alpine head unit
    By Rav3n616 in forum Car Audio
    Last Post: 17-08-2009, 10:11 AM
  2. vx series 2 electric antenna not working
    By ilovemyvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2006, 03:56 PM
  3. Blaupunkt 6 stacker Antenna Buttons not working in S Pack
    By Crintonn in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-03-2006, 06:42 PM
  4. antenna not working properly
    By Cameron in forum Car Audio
    Last Post: 15-03-2006, 10:03 PM
  5. Power Antenna not working
    By VSBerlina95 in forum Car Audio
    Last Post: 09-10-2005, 03:33 PM
