Results 1 to 6 of 6
Thread: Vt electric problem
    Vt excutive, vz berlina
    Aug 2011
    Bendigo
    Default Vt electric problem
    So I've had my vt for a for over 6 months, and I went to start it to go to work, it started fine and as I was reversing out the driveway the dash started beeping so I looked down and the oil light, airbag light and check power-train lights were all on. So I turned it off, had a look under the bonnet, all was good, went to start it again and nothing happened, turned the key, and it was like I was using the wrong key, now I have discovered if I wait a few seconds I can try again and sometimes it will start. I've been to a mechanic to see if driving it with the warning lights displayed is bad and he said it can't harm the engine, what's wrong with my car?? Btw the head unit, and speakers were professionally installed and been rechecked
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    VT's are an electric problem lol. Mine occasionally dies when driving, oil/powertrain/battery lights come on. It's the coil pack connections (they be forked), not suggesting that's the problem you have, just that VT's have the most tempremental electrics of any car known to man. Might may to check the fault codes and/or take it to an auto electrician.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
    Aug 2011
    Bendigo
    Haha, well once mine's started, it runs great and everything works fine, someone told me that it could be the body control module...
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Yeah, that fact that there is nothing else off - like billowing steam or giant fireballs erupting - it's probs ok. Check all your fluids and fault codes to see if there's a specific problem. But yes, Auto Electrician, they should be able to tell if there's a problem with the onboard computer.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    sounds like the common ABS module failure.
    do a search for it on here, you will get heaps of hits.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by wamboin23 View Post
    +1 For the ABS Module, For all the Errors that appear like that is most of the time a faulty module after reading of the same issue over the years here.
    Check you error codes.
  1. electric seat problem :(
    By holden_calais_VT_1999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2012, 04:41 PM
  2. electric aerial problem
    By ss905l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2010, 09:49 AM
  3. WH Electric problem
    By DARK SIDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2009, 11:01 AM
  4. A different electric window problem
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 02:37 PM
  5. Electric Windows problem
    By dammit in forum Electrical Wiring / Questions
    Last Post: 21-03-2005, 10:35 PM
Tags for this Thread
