Ok looked under the car, its not a very fast leak wherever it is coming from just enough to leave afew drops in the driveway each week.
it seems to be more oily toward the front of the motor. if it helps my alternater is hammered in old oil
Any thoughts on what to look at replace or check before i send the car off to a mechanic next week?
Also if it is the sump gasket should i look at upgradeing the sump to somthing else ?
Real cars don't power the front wheels, they lift them
rear main seal?
What color is it?
If it is red then it is steering fluid. I have just replaced my bottle reservoir as it was cracked around the join in the middle. Degrees and run for a few mins and see if you can pin point.
the oil on the ground is clear clean motor oil, Rearmain seal was done about 3months ago that was my first thought, the oil im guessing on the alternater is black old nasty stuff
i have a leak in the same place but i have not worked out where it is comming from
Damm holden to hell lol
my oil leak was the timing cover gasket removed the cover put a new gasket and as good as gold now
