Results 1 to 3 of 3
Thread: water pump what else?
    VT SS 5.7
    Mar 2005
    Goulburn
    Default water pump what else?
    Gotta change the water pump on the LS1, just wondering if there is anything else i should look at replacing while im at it?
    Real cars don't power the front wheels, they lift them
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    hey mate... dont forget to have a good look over your radiator end tanks as there only plastic and prone to cracking also its not a bad idea to replace ya hoses if your not sure on there age. its a really simple job once ya get into it just be sure to use the correct torques as alloy blocks are easy to strip threads. good luck
    If in doubt......FLOOR IT!!!
    vt/vx ls1
    Jul 2009
    If your balancer seal is leaking or timing cover seal leaking could always do it now while radiator is empty n pump off and out the road..
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. [VIC] FS: VN SS V8 Heads, V8 water pump, V8 oil pump
    By dans_vz in forum Parts And Other Items For Sale
    Last Post: 22-02-2011, 06:37 PM
  3. Water Temp/Water Pump?
    By Fred 96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2010, 01:58 PM
  4. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  5. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
