Results 1 to 6 of 6
Thread: VX SS Power Steering Whirring Noise
    VX SS
    Aug 2011
    Default VX SS Power Steering Whirring Noise
    Hi,
    I've got a quite loud whirring noise when turning the wheel in my VX. It's the sound i would expect to hear when the fluid is low but the power steering fluid is clean and full, no leaks or anything. Any ideas?
    Thanks!
    vt/vx ls1
    Jul 2009
    Quote Originally Posted by stinomus View Post
    Hi,
    Thanks!
    The blades inside the power steering pump may have been glazed from either over heating or running dry if fluid got too low once or twice..
    Either that or its a idler pulley..
    try replace pump and idler pulleys..
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You might have some air in the system, you can try bleeding it by turning you steering wheel from full lock to full lock a few times.
    MY RIDE
    VU Ute 3.8 S
    Mar 2011
    Maybe its your steering rack,jack the front end up and grab your wheels and turn from side to side to check
    VX SS
    Aug 2011
    Thanks for the suggestions. I'll have a look over it tomorrow, oddly I did notice it's not an issue when it's cold, only when it warms up a bit O.o
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Could be that your power steering pump is on the way out, that's how mine started out before the pump died. The steering got progressively heavier too. You'll know in about a fortnight.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
  1. VS Caprice whirring noise
    By greenvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2011, 06:37 PM
  2. Transmission whirring noise
    By justice4all3000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2010, 08:07 PM
  3. 'whirring noise'
    By snowybill in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-11-2009, 12:52 PM
  4. Whirring Noise - Power Steering Pump???
    By northqueenslandvs97 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 05:24 PM
  5. Power Steering Whirring Noise
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2008, 08:07 PM
