Results 1 to 5 of 5
Thread: Lost throttle body / TPS adaptor? Need help plz
    VX V6
    Aug 2011
    Default Lost throttle body / TPS adaptor? Need help plz
    Hey all - Just replaced the TPS on VX V6 - now just realized i had lost the adapter in the process -
    Unsure of what its actually called.
    I need some help pointing me in this direction thx
    Lost throttle body / TPS adaptor? Need help plz-adaptor.jpg
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Go to wreckers, get another.
    Ronald Reagan (1986)
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    It's called a "Drive Adapter".
    The "drive adapter" is a plastic cover that loosely slides over the end of the throttle shaft, on the TP sensor side of the throttle body. It is captured in place when the TP sensor is in position on the throttle body. The drive adapter could fall from the throttle shaft after the TP sensor is removed. Ensure that the drive adapter is not lost.
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    penjay just a question, why did you need to change your TPS? What was the symptoms problem? May help others out in the future with similar problems.
    VX V6
    Aug 2011
    Thx all - just got another throttle all solved main reason in first place CAS issues- mainly due to stalling issues when car over heats an yea bottle of water over it, and starts again also - the harmonic balancer needed replacing/ and for some strange reason also the fuel pump was dying ( normally they would just die and thats it) but anyways - I replaced them by my self /
    inc fuel pump ..
    So i decided i do abit of cleaning towards the throttle as in metal polishing etc..and yep the clip came off stupid me / and without thinking put it back and got an error code of meaning TPS low voltage/ now just in process of doing more cleaning towards the inlets and such and yep manually cleaning injectors..etc - Thanks all for the replies - hope all is solved with the TPS low voltage reading due to missing clip..
  1. Vn V6 Buick twin throttle body adaptor searching
    By hsvsv3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2011, 07:21 AM
  2. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  3. Throttle Body Adaptor
    By KIT55Z in forum General Discussion
    Last Post: 11-05-2010, 11:25 AM
  4. Lost Bit of my body kit....
    By neppirt_1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-07-2008, 07:51 PM
  5. Lost Bit of my body kit....
    Last Post: 29-06-2008, 06:36 PM
