Results 1 to 2 of 2
Thread: replacing intake manifold?
    VT calais 1999
    Jun 2009
    Gympie
    Default replacing intake manifold?
    hey does anyone know if there is a how to to replace the intake manifold gasket on an ecotec??
    VU Ute 3.8 S
    Mar 2011
    Hey mate remove your throttle body and including sensors and tubes. Remove plenum cover.(8 hex screws I think) then thier will be 6 bolts inside the plenum holding it down...remove them( I always stress to people to cover your runners when working with them open as if you drop something down thier you MUST remove it. Once the screws are out grab hold of the fuel rail and put your thumb on the upper radiator hose for leverage and wriggle it around till the manifold come loose. The fuel rail and injectors come with it. So the gasket sits between the upper and lower maifold between the runners. Remove, replace and install is opposite of removal.
  1. replacing intake manifold gaskets, which parts do i need?
    By admir87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2010, 02:26 PM
  2. intake manifold
    By stevesvx2001 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2010, 05:05 PM
  3. intake manifold
    By mattp VSII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-03-2010, 06:50 PM
  4. Intake Manifold
    By VS BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2005, 07:12 PM
