Results 1 to 3 of 3
Thread: L67 UPGRADE( ROLLER ROCKERS) used or new? pulley upgrade. need some advice.
    vr wagon
    Aug 2010
    vic
    Wink L67 UPGRADE( ROLLER ROCKERS) used or new? pulley upgrade. need some advice.
    just searching around for some parts and want some help what to go with.going for the pulley boost upgrade and the high ratio rockers. thinking of going with the mace 10psi pulley but unsure on the rockers. what size to go and what brand?. new or used?. and anybody have ideas on prices to get it installed?. can anybody recomend a good mechanic? dont mind if i have to drive to melboune to do it. im located in gippsland vic. and how much will the pulley make my s-charger whine? whant to keep it low key.
    VS Stato l67
    Mar 2009
    Melb
    As far a rockers go, I personally would not go above 1.9 ratio. Any higher than that and ive seen a fair few people around that have run into issues. Either mace or yella terra seem to do the job (id steer clear of FIT) and should take a mechanic no more than 1 hour labour to install. If you go second hand keep in mind that some rockers come with torque to yield bolts which means once the bolts have been used once they need to be thrown out and new bolts used. I think yella terra use reusable bolts but you should double check that.
    The pulley wont make it whine much for normal driving, mainly just under load at higher revs.
    vr wagon
    Aug 2010
    vic
    Yeah cool. Will go with mace then. might check out Their online store and put in an order.
  1. [QLD] New YT6650 Roller Rockers 1.8 suit Ecotec/L67 Trade for yt Snout & pulley
    By vsl67 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-01-2011, 09:54 AM
  2. Advice for my VR...roller rockers
    By FirstVR_JC in forum Yella Terra
    Last Post: 04-09-2009, 03:27 PM
  3. L67 Pulley upgrade
    By superCalais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2009, 03:37 PM
  4. Upgrade cam AND roller rockers?
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2008, 09:17 PM
  5. roller rockers + pulley kit
    By brentons_house in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2006, 08:37 AM
