Results 1 to 3 of 3
Thread: Replacing clutch master cylinder
    VT Commodore 1999
    Aug 2011
    central coast NSW
    Default Replacing clutch master cylinder
    Hi,
    My clutch master cylinder push rod has snapped and it doesn't even look the same as a new one, i think the person who owned it before me has done a dodgy on it. I am going to buy a new clutch master cylinder and need to know how to replace it, Is it easy can I do it myself??
    A step by step instruction would be handy.
    Any advice would be appreciated.
    Thanks
    Sherie
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i snapped one not long ago too. with my master cylinder (out of a VY series 1 5.7L apparently) i had the option of buying a new one or just buying a rebuild kit, which consisted of the pushrod and piston, circlip etc. a new master was $250 and the rebuild kit was $150.
    i bought the rebuild kit and left the master cylinder bolted in and took the circlip out on the cabin side, slid out the old piston/pushrod and in with the new, fiddly prick of a job but not impossible (brake fluid will pour out so have some rags there to catch it) hooked it back up to the pedal and bled it up, u could have a look at the exploded diagrams on the computer at the dealership hopefully that will give u an idea as to wether u are getting the correct replacement bits or not.
    if u get a whole new master, if u can get to the bolts holding it to the firewall/flare nuts on the lines it will be pretty easy to replace.
    i dunno why but mine took ages to bleed properly with a mate pumping the pedal and me cracking the bleed nipple, went thru damn near a whole bottle of brake fluid but it come good in the end
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Assuming you have a VT Series 1 you could use the instructions in the attachment below. Note you will need a PDF reader.
    Attached Files Attached Files
  1. VY (i think) clutch master cylinder help needed
    By dirt drifter in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-08-2011, 10:11 AM
  2. Clutch master cylinder pin
    By 93vp1car in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2011, 06:54 PM
  3. Risk of clutch master cylinder leaking?
    By Boy from Oz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-05-2010, 07:36 PM
  4. Clutch Master Cylinder
    By South West Oz Ute in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2008, 12:03 AM
  5. Replacing Brake Master Cylinder
    By dufus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 09:48 PM
