Results 1 to 12 of 12
Thread: Vx sedan rear seatbelt removal guide?
    VX s2
    Jul 2006
    Default Vx sedan rear seatbelt removal guide?
    My seat belt has stopped retracting, is there any guides on how to replace them? Eg removing trim and shelve and belts etc etc ? Had a quick search but could not find anything .
    VX Calais LS1, VS Calais L36
    Mar 2010
    It's been a while since I did mine so I'm sure I've forgotten a step, but I think it was as simple as removing the rear seats to gain access to the reel. To remove completely the c-pillar trim had to be partially removed to gain access to the top hanger bolt. Didn't have to touch the parcel shelf.
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    you just have to take out your rear seat (the side you need) then the "c" pillar is held on by 2 screws at the top of it, then it all just unclipped. and to get to seat belt real its just two bolts i think. cant remember but that should help.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VX s2
    Jul 2006
    Thanks i did it.
    Removal the rear seat via the black pull tabs
    Undo the bolt under the rear seat back
    Lift seat section out
    Take out Plastic clip
    Take out the arm handle up on the plastic trim
    take out the screw over the C piller
    Lift out.
    VX Exec SeriesII
    Oct 2005
    Here's some pictures of the seat belt assembly - wasn't too hard to change over.
    Attached Thumbnails Attached Thumbnails Vx sedan rear seatbelt removal guide?-img_0495-medium-.jpg   Vx sedan rear seatbelt removal guide?-img_0489-medium-.jpg   Vx sedan rear seatbelt removal guide?-img_0494-medium-.jpg   Vx sedan rear seatbelt removal guide?-img_0491-medium-.jpg   Vx sedan rear seatbelt removal guide?-img_0490-medium-.jpg   Vx sedan rear seatbelt removal guide?-img_0493-medium-.jpg
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by thekow View Post
    Thanks i did it.
    Lift out.
    Were you able to fix the retracting mechanism or did you have to replace the whole seat belt? I have the same problem with one of my rear belts.
    Edit: I just noticed that this thread is a bit old so I won't hold my breath waiting for a reply.
    MY RIDE
    1998 HSV VT GTS 5.7 Stroker
    Mar 2010
    Tauranga NZ
    Could be a simple fix.belt may just have a twist in it,or the top hanger is dirty which may stop it from retracting properly.Worse case senario is that the retractor unit has a broken spring,which means a new belt.Hope that helps.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by 1998GTS View Post
    Thanks for the reply. I have a feeling that it might be a broken spring.
    MY RIDE
    Mar 2010
    Tauranga NZ
    If you can pull the whole webbing from the unit,you find that the plastic around the shaft may be broken aswell.That's not good either.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The seat belt is out to it's full extent and it does not feel like there is any spring tension, if you get what I mean. It's not like sometimes when a seat belt gets stuck and you pull it a bit you can feel the spring trying to pull it back.
    MY RIDE
    Mar 2010
    Tauranga NZ
    Sorry mate,but looks like a whole you seatbelt.If you were over here in NZ i could of just replaced the unit for you.(did it for a job for about 10 years)
    VX Exec SeriesII
    Oct 2005
    When I did mine yesterday I had to replace the seat belt (see pictures above).
    Went the cheapo option and got a second hand belt on eBay for $47. The old belt wasn't retracting properly.
  1. Is there a guide on how to replace rear seat belts on vx sedan?
    By thekow in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-08-2011, 08:46 PM
  2. rear seatbelt
    By guyman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-05-2010, 11:57 PM
  3. Rear windscreen removal. vs Sedan
    By northysvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2009, 01:48 PM
  4. Rear seatbelt guide trim??
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2008, 04:06 PM
  5. Front upper seatbelt anchor point removal
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-02-2006, 09:25 PM
