Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By wortus
Thread: Vt v6 battery light goes on and of
    S1 VT Wagon
    Apr 2005
    Gold Coast
    Default Vt v6 battery light goes on and of
    Hi guys
    The last few days the battery light comes on, lights dim, radio turns of, sputters a but then all of a sudden comes good. Also seems to come good when u give it the beans. Any idea what could be causing this. Battery is less a month old, had it checked and all good. Thinking possibly the alternator but more like the regulator?
    Any help would be awesome.
    VT S pac daily driver - 08 Liberty GT-B
    Aug 2011
    Dec 2009
    The brushes are probably worn down and making poor contact with the slip rings. Take the regulator out and check how long they are, less than 5mm or so they are worn down too far. You can just get a new regulator or if you can solder go and get some new bushes and replace them for $10.00 Other than that check the output wiring is not loose, corroded etc.
    S1 VT Wagon
    Apr 2005
    Gold Coast
    thanks heaps guys. no multi, but the mode+up button on start up shows 12v at idle, 12v at 2500, 12v at everything. when off, 11.9, lights on drops to 11.7/6. kind of weird. battery isnt losing charge but seems the alt isnt putting out 14v. whats going on?
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Have a look at the brushes, as said above, sounds like they are knackered!
    S1 VT Wagon
    Apr 2005
    Gold Coast
    i'm guessing its easier to change the regulator out completely than the bushes?
  1. Please Help..Battery warning light and ABS light
    By martyrfc in forum Electrical Wiring / Questions
    Last Post: 30-04-2011, 03:03 PM
  2. Replies: 3
    Last Post: 26-05-2010, 09:22 PM
  3. battery light with brand new battery
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:48 AM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
