Hi guys,
got a problem which was completely random. Every time i change gears, and put the clutch in, it will rev about 200-500 rpm more, instead of dropping. Also when hard accelerating in a high gear i get a miss. I have been told it is an air leak, or vacuum leak.
Just need some help on how to find the bastard.
Thanks
I just checked the ECU for any faults, and there are none.
An old and not really recomended trick is to use a squirty bottle with metho in it. Small fine spray at hose joints etc at idle. If revs go up when u spray then thats where the leak is. Once again not really recommended as the chance of burning the car, house and yourself down r quite high but it does actually work
This works but highly dangerous or fun,depending on you adventure level
Cheapest but safest is simply remove the air/vaccum lines one at a time & inspect them. Dont pull them all off at once,take one off,test then put back again. When testing block one end & blow into the other by mouth or use a air gun gently,feel along the lines for any escaping air. Check lines for wear,dry spots or cracks.
A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
Thought I would go the safe bet and just book it into Holden. At least they can fix the miss and shitty thermostat in it as well.
Thanks for the help though guys.
I have used carby clean over the years and yet to have a fire in or on the engine while checking for leaks using this method just avoid sparks from the alternator or dodgy spark plug leads coil packs. to be safe use water in a spray bottle and listen for drop in engine revs when the water is drawn .
I use "start ya bastard"... Works every time I need to find a leak
If you've got a miss as well, I'd be tipping inlet manifold gaskets
Yeah ive been a lazy prick over the last week so i just bought the gasket for them to fit on tuesdy haha. I couldnt find any of my carby cleaner either which pissed me off a little lol.
