hello I have a problem to rebuild the engine of my 99 year Holden exported to Brazil.
Could someone help me with the tightening specifications of the engine as
tightening of cylinder heads
tightening of rods covers
tightening of the crankshaft bearings fixed
and how to put the engine at the point (set up chain of command)
and moreover how can I import parts for Brazil with an insurance company for auto parts.
PS: sorry for the mistakes because I'm using the google translator to write in English
PS2: My vehicle is a holden vt year 1999 (in Brazil called omega Australian to be imported from Australia to Brazil)
Does it have the 3.8 litre V6 Ecotec?
YES IS THIS SAME ENGINE 3.8 V6 12-valve ECOTEC
INFORMATION IN BRAZIL THIS MOTOR IS HARD!! ALL I NEED TO GRIPS FOR USE OF THIS ENGINE, AND ALSO WANT TO BRAZIL IMPORT PARTS FOR THIS ENGINE REBUILDING
THANKS FOR THE HELP FROM JA
Hi JA
The engine was made in the USA, cheaper and closer to Brazil to get parts from there.
99-02 Buick Chevy 3.8L 3800 V6 RWD -ENGINE REBUILD KIT- | eBay
Get a maintanence manual
HOLDEN COMMODORE VT VX 1997-2002 WORKSHOP MANUAL ON CD | eBay
Hope that helps.
Thank 9C1pack .. I contact to verify the possibility of importing these parts for Brazil and so rebuild my engine and leave it again
I thought the Buick engine was discontinued with the introduction of the ecotec? Do I have it wrong?
Olá
melhor conselho que posso dar-lhe seria comprar um destes:
Holden Commodore VT VX VY VZ Workshop Car Repair Manual | eBay
isso vai ter todas as especificações para o torque, e irá atendê-lo com qualquer outra coisa que você irá precisar.
Desculpe eu não posso ajudar com a obtenção das peças, e também muito se o meu português não é tão grande
graças dylan
If you read this
http://en.wikipedia.org/wiki/Buick_V6_engine
It explains the evolution of the engine, and also the the vehicles it has been supplied in, Buick, Pontiac, Oldsmobile (inc commodore)
Its a bit like "grandpa's axe" it has been in the family since the 60's had 6 new handles and 2 new heads, but its still the same axe that grandpa used (not) :-)
Glad it was of interest.
As these engines were sold in such volume in the USA, there is heaps of info on diagnostics and trouble shoooting etc.
If you search 3800 GM, and/or include Buick, Pontiac etc, you can find heaps
EG; Part 1 -3.8L GM Index of Articles.
OUR ADIMIRADO'M REALLY MUCH OF HELP, THANK YOU TO ALL WHO ARE REALLY help me,
AND STAFF WOULD LIKE TO KNOW MORE THING Maybe you can help me AGAIN CHECK THE PARTS THAT 9C1PACK me review BUT IN THIS NOTICE WITH THE SPECIFIED MEASURES STD PISTON AND RINGS FOR 0.20,0.30,040 AND STD 010,020,030 for bearings.
My question is: What measures IRAM REAL THAT HAVE TO BE THE CRANKSHAFT AND CONNECTING RODS FOR USE THESE PARTS AND SOMEONE CONENHECE PARTS MANUFACTURER OF THIS? ARE REALLY GOOD??
PARTS IN BRAZIL rectifiers are as follows, STD, 025MM.0.50MM, will equal the U.S. ...
TOP QUALITY manufacturers such as KeithBlack-Silvolite, Federal Mogul, Hastings, Melling, Cloyes, Clevite, EngineTech, Victor Reinz, King, Dura-Bond, and Sealed Power
These are known quality brands.
STD PISTON AND RINGS FOR 0.20,0.30,040 AND STD 010,020,030 for bearings = Imperial measurements (thousands of an inch)
I hope this is what you wanted, maybe GEN3RATD could help with the translation?
PERSONAL HELLO! MY PROBLEM STILL CONTINUES FOR ALL THAT MADE CONTACTS WITH SUPPLIERS OF MAINTENANCE MANUAL, AND SUPPLIERS OF PARTS FOR RECONSTRUCTION OF THE SAME ENGINE WILL NOT SHIP TO BRAZIL.
Does anyone here NOT HAVE THIS FORUM TO DOWLOAD MANUAL BECAUSE I WANT TO BUY VIA PAYPAL OR BANK DEPOSIT.
AND SOME PARTS SUPPLIER FOR EXPORT TO BRAZIL.
TODAY I RECEIVED AN ESTIMATE OF PARTS CHEVROLET DEALER THAT PROVIDES THIS VEHICLE TO BRAZIL.
BUDGET AMOUNT: AUD 19.070.54
VALUE OF VEHICLE: AUD 11.460.66
Brazil friendly staff is also very good people
http://www.clubedoomega.net/forum/index.php
Nm
Engine Dress cover 4 - 6
Coil Securing Screws 4 - 5
Idler pulley housing/coil mounting bolts to
cylinder head
40 - 50
Idler pulley bolt 40 - 50
Crank Angle Sensor to Front Cover
Attaching Studs
20 - 30
Crankshaft Balancer Attaching Bolt 270 - 325
Camshaft Sprocket Bolt 90 - 110 Nm plus
86 - 94 degree turn angle
Camshaft Thrust Plate to Cylinder Block
Attaching Bolt
12 - 18
Camshaft Position Sensor to Front Cover
Attaching Bolt
8 - 12
Balance Shaft Retainer Bolts 26 - 34
Balance Shaft Driven Gear Retaining Bolt 18 - 26 Nm plus
67 - 73 degree turn angle
Connecting Rod Cap Bolts 24 - 30 Nm plus
47 - 53 degree turn angle
Coolant Temperature Sender 8 - 12
Coolant Temperature Sensor 18 - 12
Brake booster vacuum fitting to upper inlet
manifold
11 - 14
Main Bearing Cap Bolts Refer to 3.12
CRANKSHAFT in this
Section
Main Bearing Cap Side Bolts 12 - 18 Nm plus
42 - 48 degrees turn angle
Rear Main Oil Seal Housing bolts 12 - 18 Nm plus
47 - 53 degrees torque turn.
Refer torquing sequence.
Knock Sensors to Cylinder Block 16 - 22
Knock Sensor Shield to cylinder block bolt
Right Hand Side
40 - 45
Knock Sensor Shield Bracket to cylinder
block Left Hand Side
20 - 27
Knock Sensor Shield to Bracket Left Hand
Side
8 -10
Cylinder Head Bolts Refer to 2.15 CYLINDER
HEADS in this Section
Exhaust Manifold to Cylinder Head Studs
and one bolt
25 - 35
Exhaust Manifold Stud Lock Nuts 20 - 27
Engine Pipe to Manifold Nuts 18 - 35
Flywheel/Flexplate Attaching Bolts Refer to 3.4 FLYWHEEL /
FLEXPLATE in this Section
Front Cover Attaching Bolts/Studs 20 - 30
Fuel Rail to Inlet Manifold Bolts 8 - 11
Lower Inlet Manifold Attaching Bolts 12 - 18 refer 2.9 LOWER
INLET MANIFOLD torquing
sequence
Upper to Lower Inlet Manifold Bolts 10 - 14
Inlet Manifold Cover Bolts 8 - 11
Oil Filter Adaptor to Front Cover Attaching
Bolts
23 - 35
Oil Pressure Sender Unit 12 - 14
Rocker Cover Fasteners 7 - 11
Rocker Arm Pedestal Bolts 11 - 19 Nm plus 87 - 93
degree turn angle.
Valve Lifter Guide Retaining Bolts 26-34
Water Pump to Front Cover Attaching Bolts 12 - 18 Nm plus
76 - 84 degrees angle turn
Water Inlet Tube to Belt Tensioner Stud
Nut
18 - 25
Oil Pump Cover Screws 8 - 14
Timing Chain Dampener Attaching Bolt 16 - 28
Starter Motor Attaching Bolts 36 - 50
Oil Pan Attaching Bolts 8 - 12
Oil Pan Drain Plug 30 - 60
Oil Pump Suction Pipe Flange to Cylinder
Block Bolts
8 - 12
Clutch Pressure Plate to Flywheel Bolts 20 - 30
Water Pump Pulley Bolts 10 - 16
Belt Tensioner Attaching Studs 40 - 60
Lower Belt Idler Housing Mounting Nuts
(Air Conditioning only)
20 - 30
Lower Idler Pulley Bolt (Air Conditioning
only)
40 - 50
Coolant Outlet to Inlet Manifold Bolts 20 - 34
Canister Purge Solenoid Bracket Attaching
Bolts
15 - 20
Upper Left Hand Side Screw
Plug (Cylinder block front face) 25 - 35
Oil Gallery Screw Plug (Front right hand
side cylinder block)
22 - 28
Throttle Cable Support Mounting Nuts 6 - 14
Throttle Cable Support Bracket Stud into
Manifold
20 - 25
Throttle Body Attaching Nuts 15 - 20
Front Engine Mount to Mounting Bracket
and Front Crossmember Attaching Nuts
36 - 65
Front Mounting Bracket to Cylinder Block
Attaching Bolts
35 - 65
Air Conditioning Compressor to Mounting
Bracket Bolts
35 - 65
Engine Rear Mounting to Rear Adaptor
Nuts
35 - 65
Engine Rear Mounting to Rear Extension
Bolts (A/Trans)
50 - 65
Rear Crossmember to Side Frame Bolts 50 - 65
Cross Member to Rear Mounting Nuts 20 - 30
Clutch Housing to Beaming Brace Bolts 15 - 20
Beaming Brace to Torque Converter
Housing Bolts
15 - 20
Beaming Brace to Oil Pan Bolts 3 - 5
Battery Harness Retaining Bracket to Oil
Pan Bolt
3 - 5
Oil Cooler Line Retainer to Oil Pan Bolt 3 - 5
Generator Brace Bracket to Cylinder Head
Bolt
40 - 60
Spark Plugs 15 - 25
Harness mounting bracket to lower 5 - 10
manifold bolt
EGR Valve adaptor to head bolts 40 - 60
EGR Valve adaptor to exhaust manifold nut 20 - 30
EGR Valve to adaptor attaching nuts 20 - 27
EGR Pipe outlet to adaptor attaching bolt 25 - 35
NOTE:
It is important to follow the given procedure to avoid
head gasket failure and possible engine damage.
5. Tighten all cylinder head bolts to 34 Nm.
The next step requires the use of Tool No.
E7115 with the torque wrench.
NOTE:
If a torque of 90 Nm at any time in step 6 is
reached, STOP tightening that particular head bolt.
6. Tighten each bolt 90 degrees in the order
shown.
7. Further tighten all bolts in the specified order
to 90 Nm.
8. The remaining reinstallation of components is
the reverse of removal procedures.
9. Start engine, check for oil, coolant, fuel and
exhaust leaks. Repair as necessary.
can't upload the pdf as its too big, will try n get it hosted later and post the link for you. has all the torques and procedures.
Here : sect-6a11.pdf - File Shared from Box.net - Free Online File Storage
oops double post
Thank ucwepn was actually very helpful this post do not know how can I repay it this helps but if there is anything I can do for you is only to say ok??
my e-mail personal barbosa.neto@yahoo.com.br
happy to help a fellow commodore driver.
And staff at this difficult issue of an engine for my recycled can not find a supplier to export parts for brazil in australia or u.s. Or is in parts but nobody send to brazil ...
But hope remains forever
Hey thats very annoying knowing they wont import parts you need, I hope you find a solution and can drive it once more!!
hello staff would like to thank everyone who helped me in the struggle to rebuild the engine of my "absolute" (as affectionately called in Brazil).
cosegui and redo the engine is already running again
Thank you all for your help
