Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By ])R@G()N
Thread: VT V6 Missing
    Jan 2008
    NSW
    Default VT V6 Missing
    Hey guys,
    Ive searched around but couldn't find anything that relates to my problem.
    VT V6 slight miss on idle. Also on light acceleration up to 25% throttle miss get a little worse.
    When you get into it it clears up.
    I have changed the plugs, leads are fine, coils are fine, new fuel filter and air filter is clean, MAF is fine.
    Any help would be great.
    VT
    Feb 2010
    Have you checked the purge hose that connects to the bottom of the throttle body sometimes this will come off and makes the engine runs rough
    Stolen from another thread
    Jan 2008
    NSW
    Nah its not rough, just that slight miss. But ill check it just in case.
    The thing that the coil packs are bolted onto, that wouldnt be the problem would it?
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    posible air leak my vt had a craked egr pipe it had miss at idle and under light load
    Jan 2008
    NSW
    Quote Originally Posted by Burnout124 View Post
    Where would i find the egr pipe? and how would i check for the leak?
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    the EGR pipe is the steel pipe thats connected between the manifold and the exhaust headers, you might be able to hear it sucking air when the engine is on to see if thers a leak
    vy ute
    Aug 2011
    south melb
    i also have sucking noise and problem with acceleration can anybody help?
    NV-MY-VT's Avatar
    NV-MY-VT is offline Sleeper Builder
    VT 2000 Olympic Edition
    May 2011
    Mornington, Victoria
    Dragon has posted some marvelous advice.
    Check the two vacuum leads on your throttle body, as well as the EGR pipe.
    Generally, any "sucking" sound coming from an engine that ISNT coming from your air intake is bad sign...
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Get a piece of plastic hose and put one end next to your ear, then move the other end closely over all the vacuum pipes with the motor running. Any leaks will be heard through the pipe to your ear.
    NV-MY-VT's Avatar
    May 2011
    Plastic hose != a straw
    Sometimes I don't think things through...
    Anyway, what worked charms for me was one of those brightly colored plastic "noisemaker" tubes that small children swing around in circles and make deep "wooaawwooaaaww" noises with. Again, as I said, I'm an idiot.
    Jan 2008
    NSW
    Quote Originally Posted by NV-MY-VT View Post
    No arguments with you there mate lol jokes.
    Thanks for the replies fellas. Ive got a day off tomorrow so ill sus it out then.
    VT Acclaim Wagon
    Oct 2008
    You might have been close to the mark when you mentioned the base of the coil pack. Undo the little bolt that holds the loom plug in the base and check for corrosion or looseness or bent pins. also look at the pins under the coils themselves. Same thing, corrosion, loose etc. Give it all a clean on suspicion.
    Jan 2008
    NSW
    ok so i didnt find any leaks in the purge hose or the ERG pipe.
    I did take a look at the plug at the base of the coil packs and the 10th (from the left) pin is missing. Would that be causing it?
    Any other suggestions?
    vxcustom's Avatar
    vxcustom is online now VXXX
    vx v6 executive
    Feb 2009
    Cranbourne, Victoria
    Check your harmonic balancer as the crank angle sensor works off teeth in the balancer. If the balancer is shot then at low revs and low to medium throttle the balancer will wobble, as revs increase the wobble becomes less and the CAS can get a better read. Have a look at the balancer at idle if it is really bad you should see that it looks like it wobbles or jumps around, give the car some revs and if the balancer seems to stop wobbling then its probably that
  15. #15
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
  16. #16
    Jan 2008
    NSW
    Quote Originally Posted by vxcustom View Post
    Yes it does looks like it wobbles, hard to describe, not wobbling out wards as if its not spinning in a perfect circle or something.
    How do i fix it? do i need a new balancer?
  17. #17
    Jan 2008
    NSW
    Quote Originally Posted by MrSirWantalot View Post
    Plugs are the right gap?
    just standard plugs, i havent gapped them. didnt think they needed it.
  18. #18
    vxcustom's Avatar
    vx v6 executive
    Feb 2009
    yep sounds like you need a new balancer, if you are not sure then get a second opinion (recommended) and if it is the balancer it will need to be replaced
  19. #19
    Jul 2010
    Dalby
    Quote Originally Posted by WPN-42L View Post
    You never know one could be slightly out, dropped, who knows.....but i guess if it was doing the same thing b4 u replaced them, chances are it aint them...just a thought
  20. #20
    Jan 2008
    NSW
    Yeh i replaced em about 4k's ago. Didnt drop em or anything lol so i guess that rules out the plugs.
  21. #21
    Jan 2008
    NSW
    My mate is a mechanic so ill get him to sus it out. Under-driven balancer here i come lol.
  1. Missing Cat
    By Jecs in forum Jokes/Humour
    Last Post: 30-07-2010, 03:28 PM
  2. VR 5.0L missing
    By hkmonaro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2010, 10:35 AM
  3. vs 304 missing(plz help!)
    By hdt523 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2010, 12:04 AM
  4. am i missing something??
    By muggo05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 03:43 PM
  5. VS Missing
    By Frog4364 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2008, 01:57 AM
