Results 1 to 3 of 3
Thread: Vu ute failing to start
    2002 vu utility
    Sep 2011
    Sutherland shire
    Default Vu ute failing to start
    Please help. '02 ute continually fails to start. Have had 2 crank angle sensors replaced, the key heads reprogrammed, the ignition contacts on the steering column replaced, a relay replaced. It starts for a few days and everything seems okay then it fails to kick over. Plenty of battery life and all dash lights come on. Have had it towed to Holden service centers twice and I am over it. I am at a complete loss. Can someone please help. Cheers
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Not loose wire to starter motor?
    Replace the slip key reader around your ignition barrel and MAKE SURE that the little metal bit next to the actual key is making contact with the slip reader.
    2002 vu utility
    Sep 2011
    Sutherland shire
    Default Re your help
    Thanks mate. I did all that with the ignition plate, etc., and no good. I am replacing the solenoid today as it seems dodgy and will see what transpires from that. cheers
  1. Bumper is failing :(
    By Bourbonated in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2011, 11:33 AM
  2. Front speakers failing
    By Jahwah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2011, 08:58 PM
  3. Heater fan keeps burning out or failing
    By v8superlegend in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2010, 04:27 PM
  4. ignition failing?
    By tombomb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-01-2010, 10:05 AM
  5. VS speedo failing
    By Clinster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 08:02 PM
