Results 1 to 6 of 6
Thread: Urgent... super 6 vacuume line Q
    VZ Calais
    Aug 2005
    Mackay Qld
    Default Urgent... super 6 vacuume line Q
    Hi guys.
    Can anyone please give me a link to a diagram of the vacuume lines on the VT supercharger?
    This is holding up reassembly.
    Thanks in advance.
    VS Stato l67
    Mar 2009
    Melb
    Im sure ive seen pics of how its hooked up on L67torque.com. Have a look there it might help
    VT commodore
    Aug 2011
    Sarina
    Thanks for that mate. The info is actually for me.
    I can't sign in to find the info, & i can't join because i cant read the bloody code box thingy! Sheesh!
    Anyone???? please???? It's holding up the job.
    It's a 99 VT.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Which vac lines specifically? Have you retained the boost control solenoid? i.e. is everything in standard form? I can help if you tell me which ones you're dealing with.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Aug 2008
    NSW South Coast
    Ok so this is a little rough, but it should get you out of trouble.
    A goes from the bottom boost tree port to the fuel pressure regulator
    B goes from the top boost tree port to the passenger side of the boost control solenoid (on the back of the passenger side cylinder head)
    C goes from the vacuum port on the side of the blower housing to the front vacuum port on the bypass valve actuator
    D goes from the vacuum port on the back of the bypass valve actuator to the drivers side of the boost control solenoid (on the back of the passenger side cylinder head)
    Hope that helps.
    Attached Thumbnails Attached Thumbnails Urgent... super 6 vacuume line Q-dscf0094.jpg   Urgent... super 6 vacuume line Q-dscf0096.jpg
    PM Me For Details
    VZ Calais
    Aug 2005
    Mackay Qld
    Thanks m8.
    You are a champion.
  1. 22s, super super low in the back super low in the front
    By beau_naulu in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-02-2011, 10:00 PM
  2. turbo oil feed line and drain line
    By python_hunter1 in forum V6 Development And Modification
    Last Post: 08-11-2009, 06:29 PM
  3. Urgent Help Required - which transmission oil cooling line goes where???
    By rocco555 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2009, 12:18 PM
  4. how do you install a vacuume gauge?
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2009, 08:57 AM
  5. Exact VE model line up, Colours, Trim options, And HSV Line up. THE GTS IS BACK!!!
    By blackahcdx in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-07-2006, 10:18 PM
