Results 1 to 3 of 3
Thread: Advice Please On Installing Rockers, VU
    2001 Commodore VU S Ute
    Aug 2011
    Australia
    Default Advice Please On Installing Rockers, VU
    hey i have a stock Ecotec V6 , and was thinking off putting some high / ultra high Ratio rockers on my car , Yet i dont have alot of mechanical Experience yet, only 17. Any tips or Advice if it is worth learning to put in myself? and how hard is it
    Cheers Etch
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    As easy as changing a lightbulb mate. Take off rocker covers (6 small bolts), unbolt the old rockers (1 bolt each), lube up the new rockers (use plenty), using NEW BOLTS ONLY, bolt the new rockers down to torque (i THINK its 20nm plus 90 degrees, using loctite on the thread), replace rocker covers. DONE
    If you don't have new rocker bolts, get yourself some cap-screw bolts from any bolt place for less than $1 each and they can be reused as many times as you want. The factory bolts are torque-to-yield and they stretch when torqued down, so one time use only.
    EDIT: Actually mate go through this, How to install rocker arms/pushrods , all you need to know.
    Ronald Reagan (1986)
    87LAG's Avatar
    87LAG is offline BOOSTED 6 FTW
    VX S S2 AUTO RAPTORCHARGED
    Apr 2010
    THE SWITCH
    pretty easy mate as above remove engine cover. Then remove accel cable bracket then remove rocker covers then remove old rocker and pedestals. Put new rocker gear on then definitely new rocker cover gaskets then reverse of before . . . Cheers and G L
  1. need advice! fitting my yt rockers ECOTEC
    By vsdore in forum Yella Terra
    Last Post: 29-04-2010, 08:21 PM
  2. Advice for my VR...roller rockers
    By FirstVR_JC in forum Yella Terra
    Last Post: 04-09-2009, 03:27 PM
  3. urgent car died after installing rockers
    By ralph_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2009, 03:35 PM
  4. installing rockers
    By Toms 50th Ani in forum V6 Development And Modification
    Last Post: 23-01-2007, 04:14 AM
  5. What's involved installing roller rockers into a V6
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2005, 11:12 PM
