Results 1 to 4 of 4
Thread: at lights problems!
    Sep 2004
    Default at lights problems!
    hey all i have a vt acclaim whenever iam at the lights the car dies out then after afew minutes of cranking the car starts again and is all ok back to normal what could be this problem?
    VT S2 Calais 5.7 A4
    Aug 2005
    Could need spark plugs/leads or vacume leak. Idle control valve? Does it happen in driveway at home? Cold/hot? Perhaps a bit more information might result in some more replies from the more experienced cheers
    VT Acclaim Wagon
    Oct 2008
    When was the last full service done? As bricat says, spark plugs, leads and vacuum leak are suspects here. Also consider the fuel pump and fuel filter. Engine needs 3 main things to run, air, fuel and spark. Unless your air filter is completely blocked you should be looking at fuel and spark. I saw another post here where the coil pack base was at fault. Loose connection where the harness joins the coil pack base.
    VT
    Feb 2010
    Dose it only do it when its hot ? could be the Crank sensor ??
  1. Changing VE sv6 lights to HSV lights. any problems with projector lights
    By SV6.VICTORIA in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-06-2011, 01:39 PM
  2. a few problems with vt lights..?
    By lizzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2010, 08:13 PM
  3. Problems with Lights
    By VL Chick in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-09-2009, 09:49 AM
  4. Problems With indicator and lights
    By PretendFriend in forum Electrical Wiring / Questions
    Last Post: 08-10-2004, 07:51 PM
  5. lights problems
    By Chris in forum General
    Last Post: 09-06-2004, 12:11 AM
