having problem , no fans turning and temperature guage stays on cold
Search these forums using the Google search bar provided.
This has been covered a number of times and your answer will be within a post already made in the past.
I don't understand how your fans aren't operating and yet your car stays cold lol, what's the weather like your way -15 degrees lol
Check your sensors mate or check for a trouble code
It is unlikely but check your engine fan relay. It may have shat itself. Just pull it out and put a known good relay with the same values in. If the fans work with the second relay, problem solved.
Id say Your temp sensor is gone.. Making it read low which means the fans will not turn on
