Results 1 to 6 of 6
Thread: 2000 VT Problems Need help/Advice
    2003 VY Calais SII Supercharged
    Jan 2011
    Pakenham
    Default 2000 VT Problems Need help/Advice
    Ok heres the deal, i used to hear a clunking sound when i turned the wheel etc thought it was engine mounts, started saving up for em and low and behold abs and traction lights came on, i thought it was weird so took it to mechanic they told me z bar needs to be replaced.
    So i bought the bushes replaced them myself and while i was replacing them i saw a few more bushes that were buggered so started replacing them. Then i found the ball joint on passenger side was buggered so replaced that too.
    So to recap i have at this stage replaced
    Z bar bushes
    Lower control arm bushes
    inner control arm bushes
    sway bar bushes in engine bay
    and passenger side ball joint.
    Pretty much almost all the bushes have been replaced in the front end, BUT my abs and traction control light still comes on once i hit 10km, then the engine malfunction light comes on, i have cleaned and replaced my O2 sensor (as i was told that may be the problem) as my fuel also had a rich smell coming form exhaust.
    The next step im going to take is to flush and bleed my brakes, i have however noticed there is some sort of leak coming form the exhaust pipe from about half way down the pipe not sure if thats related but yeah thought id add that.
    Ive done what i can without forking out crap loads of cash to a mechanic any advice to what the problem may be would be grateful or if you have experienced the same issues any feedback would be great as well.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You might have a faulty ABS module or a bad connection where the wiring harness plugs into the ABS module.
    MY RIDE
    Jan 2011
    Pakenham
    ill need to double check that ill check the simple things before taking it to a mechanic to check the harder more "expensive things" unless theres a simple way of checking things
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    faulty abs module or the abs unit itself. mine was the unit itself after fitting a new module lights remained, fitted new unit all sweet now.
    VX SS
    Jun 2005
    To check if its the abs module thats faulty, disconnect the plug and go for a drive. The ABS and trac control lights will be lit, although everything else should be off and your air cond etc should work as well.
    Jan 2011
    Pakenham
    Ok i did a self diagnosis and the code came up as code 95 which is traction control signal out of range WTF!!!!!!!!!!!!! what the hell does that mean how do i fix it and why is the car still running like shit??
  1. 2000 wh hsv grange buying advice
    By mike_is_bored316 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2010, 02:53 PM
  2. 2000 VT SERIES 2 Problems with cooling system
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2010, 09:21 PM
  3. Multiple problems with my VT need advice!!!
    By My99VTACCLAIM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2010, 09:20 PM
  4. i've got a few problems and need advice
    By manual crazy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 03:11 PM
  5. problems i have with my 2000 holden commodore V6 3.8L?
    By Abdullah in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2008, 08:54 PM
