last week i had a 10psi pulley put on my charger, mark at ttt said it had a miss and needs a service. the car had a miss when i baught it. and had it serviced and it went away. always hesitated when i put the foot down though. yesterday i changed the coil pack and dfi to one i had on my vr, pretty sure they are the same. drove it yesterday and miss was gone. hesitation was still there. today i cleaned the MAF with MAF cleaner then deleted bypass solinoid and took it for a drive. damn it drove wicked. double the boost i hav had since i got it no hesitation either. i then came home and changed the oil\ filter and went out. engine is stumbling under load and misfiring and making a weird hollow rumbling sound. what did i do wrong?
sorry changed fuel filter aswell. at first fuel gauge dropped 80km to empty and i shit. then started to go back up after 10 mins
Why would you remove the bypass solenoid?
I didn't remove it just Disconected it. The actuator wasn't opening properly. Put old coil pack back on. Still doing idles fine just stumbling under load. With the sudden extra boost could the belt be slipping? Could the MAF clean have stuffed fury the fuel? Could it be the filter?
I dont think belt slip would give you a misfire, just lost boost
Just to check, you are using good 98 octane yeah? I would try swapping your plugs with ones that have been re-gaped to 1mm. I've heard occasionally of people having trouble with the 10psi upgrade and needing to regap their plugs
Re tapped and still the same. Going down the street to buy another set of plugs and new leads. That don't work it's the MAF
Check plugs and leads..
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
VR and L67 coils are not the same at all.
VYII Calais L67
Fixed it, went over everything I did got a new set of genuine leads for $85 Holden quoted me $154 put a cheap set of plugs on and 3 out of 6 I did 2 days ago were rooted. Running great for now. Ordering a set of msd coils dfi and a Holden set of plugs. Holden quoted $160 a coil. Repco quoted $25 WTF going msd instead. While I was double checking fuel filter found it has a 3.07.1 LSD under there.happy
