Results 1 to 8 of 8
Thread: motor play time
    VT SS 5.7
    Mar 2005
    Goulburn
    Default motor play time
    Hi guys helping a mate try and find a good motor for his vt,the ls1 in it at the momment lets say doesnt sound all to good lol.
    Anyways would a motor from these guys be worth looking at
    eBay Australia: Buy new & used fashion, electronics & home d
    Real cars don't power the front wheels, they lift them
    VT SS S2 A4
    Aug 2005
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    They sound ok to me I googled them and can't find anything bad about them, if they give a warranty then I'd say go for it.
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    depending on the budget,why not step it up to the 6.0 litre from a vz or ve instead of 5.7 litre?
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    VT SS 5.7
    Mar 2005
    Goulburn
    From what i have read about the 5.7ltr-6.ltr conversion i think you have to mod/change afew sensors. seems abit high tech to me lol althou if its cheaper to just slap and play a 6ltr then id prolly go with that idea. cause i can get a 5.7ltr motor from commwreck for $2000
    Feb 2010
    IPSWICH
    Quote Originally Posted by madsav View Post
    The main sensor you have to worry about is on the crank,this one tells you the position of the crank as it rotates. The 5.7 has 24x reluctor wheel & 1 cam gear while the 6.0 has a 58x reluctor wheel & 4x cam gear. To change these sensors you would normally have to remove the crank from memory but,the is a little conversion doodad that basically plugs in & converts the signal from 24x to 58x. Everything else is fairly simple,motor just bolts in, accessories are the same etc. Start with the 6.0 litre & your ahead in power to weight ratio from the start
    VT SS 5.7
    Mar 2005
    Goulburn
    That doesn't sound to hard at all mate, and at least going with the 6ltr it won't have the 5.7 ticking and tapping noises. Would I have to change the computer over as well?will the 6spd gearbox bolt straight up and what would be a good price to pay for the 6ltr from a wreckers?
    VT SS 5.7
    Mar 2005
    Goulburn
    Well after poking around the web ive found to do the ls1-ls2 swap id need to change the wiring harness and play around with the cam gear crank gear etc, seems abit to messy for me.
    and for prices ive found that commwreck do a ls2 for$4200 and ls1 for $2000 , so another ls1 with cam,valves,springs done it will out do the ls2 hands down and save afew $$$ . thanks for the help guys
  1. re-wire vn computer into vr ( play play )
    By vks in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2011, 01:44 AM
  2. First Time Motor Bike Service
    By S.T.K.E in forum General
    Last Post: 02-10-2010, 11:01 AM
  3. Replies: 1
    Last Post: 29-09-2010, 06:51 PM
  4. Sydney Motor Show, Waste of Time and Money
    By Hot-Rod in forum The Pub
    Last Post: 19-10-2007, 04:03 PM
  5. time to play
    By Garth in forum General Discussion
    Last Post: 15-08-2006, 10:31 PM
