I have noticed there is oil in the radiator reserve tank. iv'e checked the oil threr is no sign of any waterin it .Has anyone got any ideas of what it might be.The only thing i can think of is a blown head gasket. Your help would be appreciated.
What color is it??
VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
The oil in the reservoir is brown like dirty oil.
my guess head gaskets blown between oil and water gallery ,
My guess would be the pellets that Holden recommend you use when you flush and refill the coolant.
Mine was all brown and sludgy in the over flow tank and under the radiator cap.
When was the car last serviced?
My vx s2 has the same issue was finding brown sludge under radiator cap and on over flow stick, mechanic replaced the inlet manifold gasket now all is good!
Hi i have the same issuies with brown sticky stuff under my radiator cap and in resev, tank ,removed tank and cleaned it up also replaced cap on the radiator and now not much off it but was told a heavy duty radiator flush out is the way to go run the motor with themo out heater on for 15 mins then run it out and top it up with new cooling bleed the system so no air blocks all good now .
