Results 1 to 20 of 20
Thread: adjusting screws inside lpg computer box so i can start on lpg only
    vt commodore
    May 2009
    Default adjusting screws inside lpg computer box so i can start on lpg only
    somethings up with my fuel system and had to leave vt at work
    I remember seeing a post a year or more ago were someone new which way to turn one of the 2 blue adjusting screws
    inside the lpg computer box so that there is no startup time running on petrol before it switches to lpg
    it is a italian system forgot which brand
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    vt commodore
    May 2009
    no was a ezygas installation, i am leaving now to see if i can get it to start
    strgas's Avatar
    Oct 2009
    vt commodore
    May 2009
    it is a sprintgas system, AEB 297 self learning feedback system, blue box with removable little rubber cover underneath is 2 small philipps screw electrical adjusting pots, the question is with one is the timer,
    strgas's Avatar
    Oct 2009
    strgas's Avatar
    Oct 2009
    finally found my paper work but not for the 297 module , going by the 295 module the RPM setting is done via the left hand trim pot clockwise for less rpm anticlockwise higher rpm
    vt commodore
    May 2009
    so what you are saying is that it waits for a certain rpm before it changes from petrol to lpg
    In that case it is not posible to start on lpg only, it still need petrol to turn over
    strgas's Avatar
    Oct 2009
    it can be set low enough to give a short prime time on petrol then crank and run on gas , from memory that module has a gas only start function , turn ignition on and hold the selector button for 5 sec i think it should engage the lpg system and gas only start . try that and see what happens
    vt commodore
    May 2009
    what does the other screw do and do you mean it switches to petrol at high rev
    were do i get information on this lpg system
    thinking of putting pod filter on but not sure were i put airflow sensor and the pipe runing from mixer to hole in airbox
    what plugs, leads and gap size so i get
    would like to have it running as dedicated lpg
    vt commodore
    May 2009
    turning the ignition on and hold the selector button for 5 sec worked well with fuel pump relay out thanks for that
    strgas's Avatar
    Oct 2009
    ok found the paper work for the 297 module the other trim pot is for fuel overlap timing .
    strgas's Avatar
    Oct 2009
    the pod filter should be mounted before the maf meter just as the air box is , the engine breather hose should be mounted between the maf and gas mixer ring , spark plug choice would be NGK BP6EFS with a gap of 0.8 mm , spark plug leads any good set of low resistance spiral core top gun ,IC&E , Bosch sport , many different brands all making alot of claims . why would you want to go straight gas on this vehicle as its all already running duel fuel ?
    vt commodore
    May 2009
    my fuel pump is playing up but I now think this sytem needs petrol under high load situations so will have to fix
  15. #15
    strgas's Avatar
    Oct 2009
    these systems will not add petrol under high load like a injection system can , must have a secondary problem under high load , who did the install for you
  16. #16
    vt commodore
    May 2009
    I brought the car a year ago with lpg already installed i think it was a ezygas instalation i dont think they still exist
    would anybody recomend a good gas mechanic in the outer east suburbs of melbourne
  17. #17
    vt commodore
    May 2009
    I have another breather hose coming from lpg mixer going into the airbox below filter were would i put this hose if i went to a pod filter
    I have just destroyed my second airbox aaaarrrrrrrr
  18. #18
    strgas's Avatar
    Oct 2009
    the second hose is it from the mixer or the convertor ? sounds to me its the balance line which should be fitted to the lower part of the air box for ram air so when fitting a pod filter it needs to be routed to the front of the car to pick up ram air . as for a good mechanic in the south east subs give me mate mick a ring at MECHSCAN AUTOMOTIVE SERVICES 87863989.
  19. #19
    vt commodore
    May 2009
    yes its coming from the converter
    I bought pod spark plugs and leads and idle is alot better and top end power
    I think i will get a little extender pipe and have pod inside airbox even though air box is a bit cracked should be quieter
  20. #20
    vt commodore
    May 2009
    read that if you leave pod filler screwed on loose if it does backfire it just pops off
  1. Vt v6 won't start with computer changeover?
    By frdhtr in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2011, 10:16 AM
  2. vs wont start, might be computer??? pleasse help
    By jaycecoghlan4567 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2010, 10:18 AM
  3. Facia screws
    By MJR_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2006, 10:43 AM
  4. Computer beeps when I start car (not fuel warning)
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2006, 10:11 AM
  5. Computer Jump Start Protectors
    By James Collins in forum Electrical Wiring / Questions
    Last Post: 28-08-2004, 12:57 AM
