ok so bought my vt (2000 executive) last week,
the air con sometimes stops blowing out of the vents? you can hear it still running just randomly stops flowing out without touching anything.
and secondly the heater has no heat.
im thinking il just take it be re-gassed and see if they have any other suggestions unless there is some thing i can try myself. (not afraid to spin some spanners and keen to learn)
Re-gassing won't help the heating issue as it is not like your home reverse cycle air conditioning. The heating is done by the hot water in the engine, that is why it takes a fair while to get heat out of it. A possible cause is a faulty heater tap, it is in the engine bay one the driver's side and has 4 hoses attached.
Your vent position problem will be a vacuum issue. The first place to check is the thin vacuum hose that should be connected at the rear of the intake manifold. If that is ok then it could be the vacuum solenoid.
MY RIDE
Ahk I looked at me mates vt and anoter mates vx and figured The heater problem, coming out of the front of the engine where the 2 hoses are meant to come out there's just 1 bridging it back into it self. Dunno why the previous owner done this and not sure if I wanna lol .
the water hose's?
i did the same thing to mine with the water hose's when the heater controller thing shiit itself... . i just bridged it so i could get around without a leak till brought the new controller. but just left it and never replaced it.... the old owner may have been a tight ass like me![]()
when ya vents stop working is there a hissssss coming from it till it starts to work again????
I had a similar problem with my 98 VT exec. the blower fan would just randomly stop then a short time later would start again, it turned out to be a thermal switch on the blower motor, if the motor gets too hot the switch will open and stop the motor until it cools down again. I replaced the blower motor, and never had another problem with it. pick up a second hand blower motor and fan from wrecker for $20 - 6 years on and it's still going.
