Results 1 to 11 of 11
Thread: Installing Spings
    VT Berlina
    Sep 2010
    Default Installing Spings
    Hi all,
    I've had a search around and haven't really found much on people installing springs themselves (not shocks). Is it that difficult?
    With my car im pretty keen on doing most of the modifications myself as i find it most rewarding etc etc. Although with things like suspension I want to be able to know that is has been done properly and is reliable. How many people have installed springs themselves? Would you reccomend it?
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    I've done them before. But I ended up just taking it to my front end specialist as it had massive camber and I didn't have spring compressors for the front.
    If you haven't done it before or don't really know what you're doing I'd probably leave it to the professionals.
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    vs commodore
    Oct 2009
    Tamworth NSW
    If your a bit mechanically minded when it comes to cars, and you have a half decent set of tools and chassis stands etc, then Id suggest getting a workshop manual, some coil spring compressors which are available fairly cheaply at auto outlets etc or online, and follow the workshop manual and have a go at it yourself. Its not hard or complicated work, the only thing is the wheel alignment will be out after its all reassembled again, and this usually cant be set yourself, so dont go driving it and expecting it to be better, even though it is always tempting to "try it out" when its finished, just drive it slowly to the wheel aligners, wait until the wheel alignment is set, then test drive it properly to see how it drives etc..
    If the front struts (which are the front shocks basically) have done over 100,000 k's, then its probably wise to replace these at the same time as the springs.Also replace the strut bearing and top strut mount, and lastly the front end bushes, you can fit nolothane or any other brand urethane type bushes.These type of bush will last better than the standard rubber ones, and will give way better "road feel" back through the car.
    With this all done to the front end, the front suspension will be all new again, ready to tackle another 100,000 k's or more of our crappy "so-called" highways and roads,and it wont cost too much if the work is done yourself. You'd probably end up saving a grand or two in labour costs doing this work yourself.Ive done all this to my VS front end recently for well under a grand, doing all the work myself.
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    Quote Originally Posted by Brett_jjj View Post
    agreed ^^ i did my vx clubby not long ago, it was simple really replaced all bushes in front end with nolathane now car feels sooooo solid on the road and steering is so much more responsive and direct.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Spring compressors are not needed when fitting lowered springs to a Commodore.
    Visit my Facebook page
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Correct, but are needed when removing the standard height springs from the front assembly
    Oh and a little hint, do not engage the handbrake, it will hold up the rear frame causing u grief trying to remove the current springs
    vs commdore 1995
    Sep 2011
    adelaide
    i got a vs commy and i got a deal today well some bloke i ment i got springs and shocks for the rear of my car it cost $100 for the lot its pedders brand and its super low cant wait tomoz i will be putting them in my car and iam getting the front ones $100 as well and 2 1/2inch exhurst for it $100 as well and they are brand new
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by AdamGardner View Post
    Hi all,
    Yes,easy enough as long as you know the diff between a tyre and spanner.Make sure to have a spring compressor,(short one).
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by ephect View Post
    Nope, don't even need them to remove the standard springs. Done heaps and can get all four done in under an hour.
    VT Berlina
    Sep 2010
    VX acclaim S2
    Oct 2009
    Agreed, take top nut off then the next nut, and then jack it up, u will de compress the spring as u jack it up
  1. spings
    By blueVP in forum General
    Last Post: 07-09-2011, 10:34 PM
  2. wich way do king spings go?
    By jonboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2010, 05:33 PM
  3. vs cut spings-lowered
    By cmesk8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2008, 04:54 PM
  4. King spings... camber, tyre wear.. HELP
    By bernie85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2008, 09:56 PM
  5. how to change spings in vr commodore?
    By madvrcom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2006, 03:24 PM
