Results 1 to 5 of 5
Thread: Another VY diff cradle into a VT question :)
    VT S-Pack 3.8L Supercharged - Rebuilt*
    Feb 2010
    If you have a valid reason for requiring my location, you can ask!
    Default Another VY diff cradle into a VT question :)
    So, I know there are a few posts on this, but I didn't see one asking this question. Maybe I didn't look good enough lol.
    Here goes...keep in mind I have a VT (obviously)
    Forget the explanations of what it does, how to get it, what to do with it and all that, my question is, do I have to take the whole rear end or can I simply take the frame and leave the rest of it? It's just the K-frame yes? When I went to the wreckers for one, the frame alone was $40. I didn't have the right tools with me at the time and they wanted $220 just to remove it themselves lol. So do I need the brakes, the diff etc? Or can I leave all the extra junk behind and take the frame. I don't particularly want the diff anyway coz I have an upgraded 3.45 LSD.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Have a look here . VY irs into a VT This should answer all your questions
    vx custom 600RR
    Oct 2010
    it only creates a error to counter a design fault
    toe in to fix negative camber will still be a problem with tyre wear
    even VE 's still suffer from this problem
    vx v6 comodore
    Jan 2011
    sunshine coast
    It all comes out as 1 unit, then from there you will have to undo diff,driveshafts,(brakes <if u havent already remove them). so u can just take the cradle but you will have to put all the bits inside the car because they wont bolt back on the car without the cradle(wich u will take)
    I brought a vy rear cradle and it came with all the bits but i just took them off and used all my original stuff.
    u will need the big U shaped frame but also the bits that the brake rotors are attached to because your original ones on your cradle wont have the holes in them for the ajustment rods to attach to. so just grab the whole thing minus diff-driveshafts-brakes and ull be on your way...sorry not the best explanation but i forgot what all the stuff it called.
    Hope that helps.
    Feb 2010
    Quote Originally Posted by vx_commodore View Post
    Hope that helps.
    Na that's a huge help mate!
    Cheers!
  1. irs lsd diff and cradle
    By nathan01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2011, 11:11 PM
  2. diff cradle
    By VTPREDATOR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-06-2010, 12:22 PM
  3. Diff cradle question
    By Jisso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2010, 09:19 PM
  4. Wtb In Sa Diff Cradle
    By PRO AERO in forum Swap / Wanted to Buy / Trade
    Last Post: 07-11-2006, 07:13 PM
