Results 1 to 5 of 5
Thread: fan wires unplugged
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    Default fan wires unplugged
    I went to a mechanic to get my driveshaft fixed. I left my car there for a couple hours. Came back home. But when I drove two days later on the higway and went to a friends home when I parked the car the radiator was leaking. There was a hiss sound coming like if there was some kind of pressure release valve and water coming out. Luckily my friend was a mechanic and both fan wires were unplugged! The car did not overheat because I was in the higway all the time and the temperature was constant just a little more than normal. Plug the fans back in filled it with water. The leak stopped after two minutes and the car is running fine now no leaks and fans working. So do these cars have a pressure relief valve. My car is 2000 model. Also the car never did this before and when I went to the mechanic then this happened.
    VX SS
    Jul 2011
    When a radiator gets too hot it will boil over, the "leak" would of been fluid escaping through the coolant overflow line....nothing to be concerened about mate, its there so you dont blow up your radiator with too much pressure
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    VT Acclaim Wagon
    Oct 2008
    Check your overflow reservoir. If it is normal level then look for any signs of leaks elsewhere. Might even pay to get a cooling system pressure test done now that you have seen it leaking. Better safe than cooked motor. And thermo fan plugs do not just fall out, they have a secure fixing setup.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by ucwepn View Post
    sounds like dodgey mechanics looking for more work
    Exactly what it sounds like mate. Id go back to them and say that I only just checked the cooling fan plugs and wiring the other day because the thermos werent working because of a faulty relay, and then ask them why they had been unplugged, as the thermos were obviously plugged in and were working fine just before the car was dropped off to them..Id love to see the look on their faces.
    These "so-called" mechanics needs a flogging if thats what is in fact going on there.
  1. What wires??
    By VY_utester in forum Car Audio
    Last Post: 22-12-2010, 02:52 PM
  2. VR BUICK COIL PACK WIRES + and - which wires???
    By H1GHROLLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 09:32 PM
  3. what r these wires
    By Matt_vp in forum Electrical Wiring / Questions
    Last Post: 17-01-2007, 10:59 AM
  4. What would these wires be for?
    By VSteve in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2006, 11:00 PM
  5. Amp Wires?
    By todds_vt_2005 in forum Car Audio
    Last Post: 19-03-2006, 11:46 PM
