I have a 2000 model ss with a high output ls1 and m30/4l60e transmission. If going from a slow start I can feel a very small jerk when it shifts from 1 to 2. But if I go a full start and fully slam the accelerator it has a hard jerk. No shifting issues or grinding. All gears shift smoothly and queitly except the 2nd gear. There is a faint thud when shifting to 2nd. Is this an easy fix.
Does it have a corvete servo? If it is shifting unormally hard though I'd say you've done a celluloid. Not major
Yes the billet are a bigger surface area again. I found you get a harder more noticeable shift when accelerating with a slower build up instead of just flat knacker.
check you trans fluid level too. I've found that if the level drops too far it makes the shifts harder/harsher
They both perform the same way though, if you weren't sure you could have either.
Lol yeah they throw you back a bit...puts more strain on your tranny than a corvette.
Its prob a celluloid if it's that bad, the shifting is suppose to be so harsh without them.
You have to drop your pan though to find out.
