Hey fellas,
new to the forums, been having an issue with aforementioned 2000 VT S2. When the ignition is off I get an audible beep about every 2 minutes that doesn't quit, i.e goes all day and night.
I've reset the service clock
Checked all wedge fuses
Did the service computer thing connecting pin 5 and 6, which came up with Code 12 i.e everything ok.
Only thing aftermarket is the stereo and an old nokia incar kit that i've never used.
Any help greatly appreciated,
Edcom
maybe get a vid of the noise on here
just waiting for a mod to approve the vid
some stereos have a detachable face that will beep to remind you to remove faceplate
Try handbrake not off correctly
that sounds like a mobile phone/bluetooth connection error
Yep sounds like the carkit, Mobile Phone/Bluetooth sound cause mine sounds the same when I connect and disconnect it
Try resetting your car kit by disconnecting the battery for a few minutes. My car car kit freezes every now and then and that is the way I reset it.
MY RIDE
Sure doesn't sound like any sound the car could make. like everyone has said here check your sound system blue tooth etc. and if the sound system is factory standard with no mods omg I'm lost.
Originally Posted by Yoda
Will do fellas, thanks heaps.. will update with result
*edit* No good, will take it to a sparky and get 'em to pull out that car kit anyways.. never use it.
And there are no bluetooth devices in the car.
Hey do you have an etag? When the battery in them gets low it beeps
nah bud no etag
Whenever my stereo powers up or powers off there is a beep beep its a sony, maybe there is some bad wiring behind the stereo that could be touching live power such as the memory wire to the accesories power input to the stereo, is the noise coming from your speakers or dash? long shot but could happen i guess.... good luck with it..
WTB lsd 3.46 for vx in Toowoomba area
Also got a few used vx ls1 parts i need to get rid of basically a complete motor minus block and sump, pm me.
Just wanted to thank all u fellas for your help... haven't got it sorted yet, but narrowed the bastard down
Did you work out exactly where the noise is coming from? Such as speakers or behind dash or something?
My only thought is with the stereo, if it's got an internal battery that's been going flat perhaps the beep is telling you what's the product number? If you narrow down precisely where the beep is coming from I'm sure we can figure it out![]()
The New Ride - The Class 2 Shuttle Craft (VE)
Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
you havnt got a new phone in the last couple of weeks since it started have you sounds like the nokia car kit trying to connect to a phone
