Results 1 to 5 of 5
Thread: power steering leak
    VX S2 S Pack
    Dec 2009
    Default power steering leak
    SO im losing a heap of power steering fluid, every day the level is about 5mm lower then the previous, the hoses around the canister are dry, the hoses right down the bottom are a bit dirty, but they dont look like they are leaking. The ground under where i park my car is showing that the leak is somewhere right up the front near the radiator, on the same side as the fluid canister, any ideas where it might be leaking from?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Most likely from the pump itself. If it is the pump, a seal kit can be purchased from Holden quite cheaply.
    MY RIDE
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    would a pressure test show with power steering fuild?
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by DanLucas View Post
    Dunno, but I'd degrease it all, including the rack and look for the fresh, red fluid after the next drive. Should stick out like dogs balls.
    VT
    May 2010
    Wollongong
    hey mate had the same problem on my vt wagon turned out it was the power steering rack and my pump had a small leak. So focus on that area and see if its the same for you
  1. Power steering leak
    By FATASS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-08-2011, 01:42 PM
  2. power steering leak
    By kniever in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2010, 07:53 PM
  3. power steering leak help please.
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2009, 10:55 AM
  4. power steering leak help please.
    Last Post: 24-03-2009, 10:42 AM
  5. VN power steering leak
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2008, 05:21 PM
