Results 1 to 5 of 5
Thread: LS6 manifold conversion
    VT SS 5.7
    Mar 2005
    Goulburn
    Default LS6 manifold conversion
    Swaped out my vt manifold to the LS6 manifold today. didnt noticed any diffrence in HP but did noticed it has more torque eaither way only $100 and pretty nice smooth gain
    Real cars don't power the front wheels, they lift them
    vt/vx ls1
    Jul 2009
    Post some pics if you can madsav, iv got a spare vx manafold lyin round, But im pretty sure the one im using is the the vx onwards one or ls6 manifold, the vx one thats a little better then the vt one, i had not long ago cleaned mine and cleaned the injectors and put in new seals seemed heaps better ;p now tha catch cans will keep it clean hopefully, did you change your injectors i think the ls1 ones are slight diff?, i got spare set if you need.
    I remember ages ago someone saying there is a obvious difference in moulding just behind the t/b so if you post pics maybe we can compare.
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    VTII used the LS1 manifold, VX used the slightly better LS6 manifold. As stated small gains, pretty good cheap mod
    If it isnt tuckin, it must be suckin
    VT SS 5.7
    Mar 2005
    Goulburn
    Hi mate ,yep swaped out the injectors from Vt-VY clubby injectors im told its better for getting the car tuned but not 100% sure. and yep the like GEN3RATD said you would have the LS6 manifold. i think i slaped up a post somewhere with the diffrent part numbers if that helps any
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    VT use a 24lb injector while VX use a 28lb from memory
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  2. VN Heads and manifold conversion Help Please...
    By needwork2-4fillhabbit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2009, 09:22 PM
  3. Stock Exhaust Manifold turbo conversion?
    By Post Vintage in forum V6 Development And Modification
    Last Post: 21-03-2009, 11:02 PM
  4. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  5. vp inlet manifold to vn engine conversion
    By Bandit101 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2006, 11:59 PM
