Results 1 to 8 of 8
Thread: changes to exhaust
    vt calias 5lt
    Sep 2011
    hills district
    Default changes to exhaust
    Hi everyone I changed exhaust manifold to pacemaker extractors out of a vp v8 only mod done was lift the motor and plug up sensor, since then motor warning light comes on after 10 min. of driving please can some give me some advice.
    When there is a change over like this do you have to buy new sensors?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    vt calias 5lt
    Sep 2011
    hills district
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by shaun vt nut View Post
    opened up the sensors !!!!!
    what does this even mean, you probably need new 02's
    vt calias 5lt
    Sep 2011
    hills district
    I was told to open up the fins to allow more exhaust to pass though the sensor if it works I'll let you know got nothing to lose buy trying it. Have you got any idea how much to replace the O2's and do I have to buy special O2's because of the change?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You don't need to use "special" O2 sensors, and you don't need to "open them up" either. The VP only uses one sensor and the VT has two. I'm surprised the VP extractors even fitted the VT as the K frame and rack are in different positions.
    You will need to fit two sensors back in right at the collectors where the pipes merge into one on each side.
    Visit my Facebook page
    vt calias 5lt
    Sep 2011
    hills district
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Is there anyway of testing the 02 sensors ?
    test the sensor using a multi meter and read the voltage given off while the engine is running voltage should always be changing above and below 450mv
  1. [VIC] FS Monasro exhaust, vx ss exhaust, K&N filter, various Maf's LS1 turtle shell & more
    By SenatorMike in forum Parts And Other Items For Sale
    Last Post: 10-04-2011, 10:39 AM
  2. VX Exhaust System - REDBACK 2.5" CAT BACK EXHAUST
    By tdirago in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2011, 09:10 PM
  3. Steam coming out of exhaust, also notice liquid sitting in exhaust tip
    By v8s&2wheels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2010, 12:35 AM
  4. [VIC] Swap my sports exhaust for stock standard exhaust - vu ss - cat back
    By supachippy in forum Swap / Wanted to Buy / Trade
    Last Post: 21-06-2010, 12:05 PM
