Results 1 to 6 of 6
Thread: WH Statesman indicator problems
    VS
    Jun 2011
    Bacchus Marsh
    Default WH Statesman indicator problems
    I'm having a problem with my WH statesman, very rarely (mostly when the car is cold I've noticed) when I flick my indicators on (either left or right) they make a very bizzare screeching noise, and the lights for them don't flash on the dash nor do they work on the outside of the car, but apon switching my hazards on and off everything is back to normal again. Anyone have a similar problem? or knows what's going on?
    Thanks.
    Matt.
    VS l67 statesman
    Dec 2008
    Ive had it happen before it turned out to be the indicator stalk/switch was stuffed and wasnt quite switching all of the way
    VS
    Jun 2011
    Bacchus Marsh
    Quote Originally Posted by vsl67 View Post
    Ohh that's not to bad then, so I just need to replace the indicator stalk you reckon?
    WH Stato
    Jul 2004
    Moorabbin
    Quote Originally Posted by mattyb220992 View Post
    Yup, that should fix it.
    I've seen this problem often, even to the point of shorting out & smoking so attend to it asap!
    <a href=http://totalcommspares.com.au target=_blank>http://totalcommspares.com.au</a>
    VS
    Jun 2011
    Bacchus Marsh
    Quote Originally Posted by The Dok View Post
    oh #### haha. I will.
    Thanks heaps.
    SBP
    SBP is offline
    WM STATESMAN
    May 2012
    oak park
    Hope it all works out Matt, my problem is with the cover's on both front indicators on a 2007 WM Holden Statesman. The covers were replaced in 2009 due to spider cracking of the covers which in turn caused condensation and now the same thing has happened again. Any one else having this problem or know how to fix it?
    SBP
  1. Indicator Problems
    By adamdunford86 in forum Electrical Wiring / Questions
    Last Post: 06-11-2010, 06:08 PM
  2. Indicator Problems
    By adamdunford86 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2010, 10:22 PM
  3. Indicator Problems
    By adamdunford86 in forum ASR Audio & Electronics
    Last Post: 03-11-2010, 04:02 AM
  4. vr statesman. front bar indicator replacement?
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2009, 01:36 PM
  5. Indicator problems?
    By Noy in forum General
    Last Post: 05-05-2007, 10:45 PM
