i got a 97 vt and just had a new power steering pump put in as the old one was whining and on deathrow. upon replacement and putting the drive belt back on it is now loose. the pulley seems ok. can the drive belt stretch out?
How loose are we talking?
These have an automatic tensioner on them.
Originally Posted by Reaper:
Originally Posted by Jecs:
really loose. the automatic tension has sprung back to position and seems ok but the belt is loose as if it has been stretched
Did you use the same pulley on the pump or did the new pump come with a pulley, if the pulley is new is it the same size.
Is it possible that the belt has not been put on in the correct sequence.
MY RIDE
its the same pulley just a new pump. and the sequence i looked up and looks correct it has me stumped
It will be the way u put the belt on, next to the crank it will go around an idler everyone misses that
and that i did i checked again and due to poor lighting i did miss that. gold star to you good sir thank you and thank you to all who helped
