5Likes
hi i got told that you can clean a car with degreaser and water no matter the colour of the paint but i thought i was only white car you could clean it? is this true? and i got told it cleans the car up better?
hey mate from what i have read and searched on google every one say its a big no no but i have read on a few different sites that you can as long as its a water based degreaser and u wash it off fairly quickly and dilute it please dont try it under anything i have said as i have not tried it personally
wash it normally, if you have a lot of tar /bugs that are hard to get off, spend a good hour with a couple of soft clothes and a nice little product called Bug and Tar Remover (suprisingly enough) just make sure you rewash the car after using the bug and tar remover as you don't want to leave it on your paint.
there are products made specifically for cleaning a car, alot of research has gone into these products. why would you want to use degreaser instead?
thats like saying i know you can run your car on unleaded petrol, but i was thinking of trying a tank full of citronella oil instead because i hear it burns.... and smells better
Degreaser can damage paint work, especially if you leave it on there for too long.
If your car doesn't have a clear coat, I would recommend the green Armour All cleaner (forget what it's called), then a cut and polish cleaner like Kitten No2, than apply a wax.
If you have a clear coat then use the blue Armour All, then a No1 Polish (for clear coats), then a wax.
But not degreaser...
The New Ride - The Class 2 Shuttle Craft (VE)
I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
When I light the nitro on my HQ 454 Monroe!
Just use car soap, it isn't that badly priced.
Keep in mind if you upset the pH levels of your paintwork it'll fk up quicker then a St Kilda footy player in the off season
After I have done work to my car it always ends up with grease in places it shouldn't have grease so I just spray the whole lot with degreaser and hose it off within 60seconds and it come up a treat. The car shampoo is crap for removing grease, dont care what you buy.
I have airbrushing and good paint to match, never had an issue....
Wasn't the situation I was referring to but carry on
Nice and simple, god knows why the name escaped me. I use the green as I live in a rural area and do a lot of km's so my car gets very dirty very quickly. I only suggested it since the OP wants to use degreaser, figured he needed a bit more kick than general car wash, you're right though for most people the 'car wash' is fine... that's if they even bother to wash their cars :P
I knew a guy that had a show car look paint job that did it. he allways said if it's used under the bonnet and it's still going on the paint and doesn't kill that. why should the body be any different.
Originally Posted by Yoda
You may be surprised to know that most new cars are cleaned with a degreaser such as Prepsol during pre-delivery.
Which tar & bug remover are you referring to? There are plenty available.
What? A degreaser won't do any more than strip waxes and sealants. Normally you don't want to remove wax and that's why ph neutral shampoos are preferable. Nothing to do with the paint.
Can you? yes
Should you? no
Is it ok to use carby cleaner mixed with brake fluid? I got told it works a treat.
Can you seriously not afford a $5 bottle of Armour-All wash and wax??
Ronald Reagan (1986)
Wd 40 works well on tar
mix a bit of kerosene into your soap also does wonders. Alot of truckies do it and you rarely see a truck thats got crap paint
just buy some car wash soap ,its cheap as and wont #### your paint.
Degreaser won't #### your paint either.
Used to wash trucks with degreaser first then truck wash. Washed plenty of cars with degreaser as 304runner has done, never had an issue. You are washing it, it's not like you will be leaving it to soak over night. Just wash with soap and give it a wax aftwerwards and it will be all good.
Degreaser will tear the wax's and sealants from your paintwork leaving it at the mercy of the elements, in time your paint will become oxidised/faded. Neautral ph car wash is the best![]()
Gold Coast Mobile Detailing http://www.preferredcarcare.com.au
Degreaser won't #### your paint, butt dont use it.
