Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Jesterarts
Thread: Newby - VX unknown coolant leak
    VX Executive S1
    Sep 2011
    Default Newby - VX unknown coolant leak
    The other day as i was driving, the temp gauge suddenly shot right up to hot, i immediately pulled over to find about 3L of coolant covering nearly everything on the left of the block. Im yet to find the cause of this leak and am unsure as to what it could be.
    Things I've ruled out are:
    -Radiator (Brand new)
    -Top and bottom hoses (checked)
    Ive had people suggesting everything from core/welsh/freeze plugs to water pump and heater hoses, but there doesnt seem to be any ominous sounds coming from the pump and the heater hoses look alright, as for core plugs im praying its not, from what ive heard to replace them would mean removal of the engine?
    Any suggestions/advice would be greatly appreciated to get it back on the road ASAP thanks.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Left of the block looking front on at the car or left of the black as in passenger side?
    If it's the driver side of the block, I would be looking at the heater tap. That is notorious for getting brittle and bursting.
    Good luck.
    VX Executive S1
    Sep 2011
    holden commodore super 6
    Sep 2011
    delahey
    Could be heater tap or thermostat getting stuck open. Good thing u pulled over straight away. A similar prob happened with me the temp fluxuating. $1700 later the manifold gasket all hoses rocker cover gasket. New themostat and new radiator
    VX Executive S1
    Sep 2011
    ouch, ive removed the thermostat, tested it as well and its all fine, currently removing heater tap
    VT calais 1999
    Jun 2009
    Gympie
    VX Executive S1
    Sep 2011
    thanks for the help, just got the heater tap off and found the whole bottom connector had a crack through it, i just snapped it off with minimal force, think I found my problem. cheers
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by slurrydog1 View Post
    1. Glad it's looking like it's sorted.
    2. Damn I'm good.
  1. VX Coolant leak from Coolant Reserve?
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 09:50 AM
  2. Overheating - unknown coolant loss - tick tick tick - hard starting
    By Greg_Sian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2010, 07:46 PM
  3. coolant leak WTF??
    By wildwabbit in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2010, 06:55 PM
  4. Coolant Leak
    By inais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2009, 11:19 AM
  5. Unknown leak, any help would be greatly appreciated
    By rancid_b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2009, 12:42 PM
Tags for this Thread
