Results 1 to 6 of 6
Thread: Problem after changing gasket :s
    VT Executive
    Apr 2010
    Default Problem after changing gasket :s
    Hey guys,
    I changed/replaced my intake manifold gaskets on my v6 vt and now it idles very roughly with the rpm fluctuating between 750 (normal for the car) and 1000 rpm I'm too scared to take it for a drive plus it isn't showing any error codes and the engine light isn't on. It was 100% fine before this.
    Has anyone else had this problem???
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    did you disconnect any sensors ? if so did you plug them all back in, I'd check all your wiring first, I guarantee it's something simple
    VT Executive
    Apr 2010
    Last time it was the Injector fuse that went, but I double checked it has to be something small but it's frustrating it's always something tiny that takes ages to find
    But if a sensor is unplugged, wouldn't it show when I run the error codes?
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    did you leave a rag in there somewhere?
    maybe you put the gasket on wrong?
    where any of the injectors/plug leads disconnected?
    If in doubt......FLOOR IT!!!
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Did you use sealant in the corners? If not you'll have a huge vacuum leak. The error codes your getting will be vacuum related, like idle speed too high.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    I noticed the same when i did mine once. it tuned out to be a missing injector o-ring
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  1. Changing Manifold Gasket
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-09-2010, 08:14 PM
  2. changing Sump Gasket
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2010, 06:36 AM
  3. Changing head gasket - Requirements ?
    By Olle in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 05:58 PM
  4. Changing manifold gasket on VH
    By VS_Wagon_Baby in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-12-2008, 09:37 PM
  5. VK - Changing rocker cover gasket
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-12-2005, 10:38 PM
