Results 1 to 12 of 12
Thread: over heating.
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    Default over heating.
    hey guys problem with my vt s2 spack.
    when i was driving home tonight, my fans kicked in but didn't turn off until i turned the car off. but my dash was reading that the car was not over heating, the dial would sit about 3/4 of the way up just below the overheating part, but the engine was quite hot.
    so naturally i popped the hood, looked for coolant leaks around the water pump/radiator/thermostat heater valve thingy, and i cant see any visible leaks or any signs of leaks, nothing fresh.
    the only thing i can think of is my car is due for a service on saturday and a couple of weeks ago i topped up my coolant with water, now could that water be boiling? causing this? if so il fix it asap.
    any help would be awesome.
    Dan.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    3/4 is a bit high, they normally sit below half. Did you have the aircon on?
    MY RIDE
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    Quote Originally Posted by accentstencil View Post
    i did for about 2mins before driving but turned it off, and only noticed about 10mins later when the fans kicked in and the temp on the dial started rising.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could have air in the cooling system and just need to be bled. Adding plain water shouldn't cause the problem.
    MY RIDE
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    ok so just continue with the service? and fingers crossed should fix the problem.
    are there any other ways that could cause this problem tho?
    thanks heaps for your help.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could also be a that the thermostat is not opening fully or at the right temperature.
    MY RIDE
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    ok mate, if the problem consist after the service i will look into.
    thanks.
    VR Executive
    Aug 2011
    Replace the Thermostat is only cost $12 and also replace your radiator top tank cap this is cheap too then top up the system and make sure you bleed any air out. 3/4 is to high something is wrong get it fixed before it cost you a set of headgaskets and labour.
    Try parking it over cardboard after a drive to see if there are any leaks.
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    hey mate how old is your radiator? my clubsport did something similar when i was towing a boat last year and had a car bra on, got up to 3/4 so we stopped and pulled the bra off. not long after that the radiator srung a leak so i whacked a new one in, i had a look at the fins in the old one and only a 'few' in the middle were not blocked. now i have a new radiator i can tow a boat with the car bra on in 40 degree heat with no dramas. something to look into, and the thermostat thing is a good idea.
    johnno.
    98 VT Executive
    Feb 2010
    I had a fair few overheating issues aswell, at first I replaced the thermostat and everything was sweet. 5k km's later and it was overheating again.. this time with a few issues, cracked left radiator tank, radiator cap wasn't allowing coolant back in from the overflow tank, thermostat wasn't opening fully and air was in the system. To think this all happened within 5000k's eh? ahh well all fixed for now..
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    thanks for all the replies guys.
    and ive checked for leaks and nothing..no new sighs of leaks either nothing fresh. il change the thermostat tomorrow.
    but im a bit unsure on the radiators age, but the car doesn't say its over heating just temp goes up to 3/4 and the fans kick in. and last night i pulled over and it went away.
    my old VT has the issue of over heating and that had a crack in the radiator.
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    quick update for people who have this kind of problem in the future.
    brought a new radiator/thermostat today. servicing the car and installing the parts tomorrow hopefully all goes well.
  1. Over heating
    By p8ence in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2011, 10:58 PM
  2. vs box heating up??
    By vsbrea in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2009, 02:02 PM
  3. vz over heating
    By tommo25 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-01-2009, 04:59 PM
  4. over heating
    By crew.man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-09-2008, 07:10 PM
  5. Heating VS
    By EmmY957 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2008, 09:22 AM
