Results 1 to 6 of 6
Thread: VT SRS/heater
    VT Acclaim V6 Wagon
    Sep 2011
    Default VT SRS/heater
    Morning All,
    Trying to RWC my VT and I've got two main probs.
    1. SRS light stays on during driving. Checked clock spring connectivity (OK) and today will drive to wreckers and try another airbag. If that fails what is my next angle of attack?
    2. Leak in the heater core. Crossing fingers it's a broken hose, but if it needs replacing do I need to deactivate the air con? May not need to the heat for a few months, so is a working heater a prerequisite for a VIC RWC?
    Kudos to all the committed members that makes this site invaluable (new member today)
    Matty
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The best way to find out what is the problem with the SRS is to get the trouble code read and that way you will know for sure rather than buying things in the hope of fixing it.
    MY RIDE
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by ucwepn View Post
    Isn't srs the seatbelt pretensioners?
    I think SRS refers to the whole system. If you look at the horn pad and the passenger airbag cover you will see "SRS Airbag" written on them.
    MY RIDE
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    VX Calais LS1, VS Calais L36
    Mar 2010
    If an SRS code has been thrown due to a faulty part, I do not believe it will clear the light even after replacing the part. You need to get the codes checked and cleared at Holden. Other mechanics may be able to do it, I don't know about that.
  1. Heater Tap
    By Stugdum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2011, 10:06 PM
  2. heater tap or heater core
    By calais24/7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2011, 09:45 PM
  3. Heater tap.
    By VYMAD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2011, 10:44 PM
  4. vp heater tap
    By pprkut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2009, 04:43 PM
  5. Where is heater tap
    By viper05 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-05-2008, 11:31 AM
