Results 1 to 10 of 10
Thread: Clunk from lowered vt wagon
    VT
    May 2010
    Wollongong
    Default Clunk from lowered vt wagon
    well guys I have hit a problem on my vt wagon
    It has been lowered at the rear and there seems to be a loud clunking noise when going over bumps in the road or speed humps sound to be like its coming from the right hand side.
    I have had the car up on ramps and everything and I can't seem to find anything loose at all.
    Im really stuck. It couldn't be my shock bottoming out could it cause even the smallest bump makes the clunk noise.
    Anyways any help would be much appreciated.
    VX SS T56
    Feb 2006
    Quote Originally Posted by wootown View Post
    make sure you check that yout rear link bushs (think that is what its called) are tight.
    I had a clunk for ages andchanged rear sub frame bush and shockers, but all it was was a loose nut and bolt on the link bushes.....
    VX SS - Twin 2.5 cat back - MAFLESS Tune - MCAI
    VT
    May 2010
    Wollongong
    back under the car i will go tomorrow for a look.
    Could you please give a little description of what I'm looking for like where about these rear link bushes are there not attached to the sway bar are they?
    Cheers mate
    Will let you know of the outcome tomorrow.
    VX SS T56
    Feb 2006
    Cheers mate
    on the back swing arms, about half way along you will see a link which attaches to the sway bar. You will see the nut and bolts im talking about, you cant miss them.
    VT
    May 2010
    Wollongong
    nope they don't seem to be loose at all
    its like when you hit a speed bump ins like doonk then wen you go down again it go doonk again i cannot seem to find anything out of the order nary
    VT
    May 2010
    Wollongong
    Actually just thought of something might pull the shocks out and check above that top plate where the shock mounts and make sure that rubber spacer thing hasn't poped out between the plate and the bolt holding the shock.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Have a look and see how close your exhaust is to your rear control arm (where it bolts to the body ).
    vs v6 wagon
    Apr 2010
    I has a noise like that on my VS Wagon after I had the rear springs retensioned turned out the rubber spacer that sat between rear spring and the rear support was not installed correctly. Metal touching metal.
    VT
    May 2010
    Wollongong
    I'm starting to think its the sway bar hitting the underneath of the car. Its hard to detect and remove this problem its driving me crazy lol
    VT
    May 2010
    Wollongong
    ok guys FOUND! the problem thank god now to fix it
    ok so its my rear roll bar it has popped out of the mounts "hard to explain where abouts" its like ontop of the Control arm one side of the bracket bolts in and the other slide into a joint anyways my problem is both bolts are missing dunno how that happened so now its just the matter of bolting the thing back down so it doesn't clunk anymore. I did manage to clip them in and went over a couple of speed humps and all went well no clunk until they popped back out so I need the bolts.
    Im all so gunna see if I can find another vt or something and have a look under it to see if I'm correct.
    I did jump under my dads VE and had a look and it was bolted down with the same sort of bracket and that I know there completely different cars it was just to give me a general idea if I am right.
    The hard part is going to be getting these bolts in and trying to find the correct ones.
    cheers
    EDIT: managed to find a photo of the mount I'm talking about its the one up the top where the top arrow is pointing.
  1. Vs wagon lowered at what price?
    By supa2256 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2011, 06:46 AM
  2. VT Wagon lowered and wheels
    By ratzy in forum VT - VX - VU - WH - V2
    Last Post: 22-04-2009, 03:59 PM
  3. [QLD] WTB VZ Wagon lowered springs - Not too low though!
    By kinga in forum Swap / Wanted to Buy / Trade
    Last Post: 31-01-2009, 03:31 PM
  4. VZ Wagon Clunk in Drive Chain - Warranty
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-11-2008, 07:46 PM
  5. Clunk in the front end of VS wagon
    By Old Colts in Oz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2008, 02:45 PM
